Block To Head Oil Restrictors Question - Rb26dett
If by "flap disc" you meant "chocolate wheel".... then they are OK for getting off stubborn remnants. But not for stuff with bulk depth. If by "flap disc" you meant "abrasive paint f**ker"....
Beauty, thanks guys, got some ideas now. I note that none of you agreed with the flap disc so that's good to know. 馃憣馃徎
I had small pin holes in my glazing putty but didn't want to put more putty to not make a mess again and I put 2 coats of epoxy primer to prevent it from rust. Though you can only see the pin holes if your eyes are almost against the panel. Do you think when the 3x coats of high fill 2k primer and 2 base coats go on that it will be visible?
I would soak the foam with this stuff for about 10 mins then scrape off
Warm it up with a hair dryer or gently with a hot air gun.
