Hi all,
Well my '94 GTR has started making a squealing noise on boost. Autotech say it could be a dying turbo (they were servicing it at the time).
The guy I bought it from had recently had the turbos 'overhauled' (I have the receipt) with steel wheels. But then the guy at Autotech says they're HKS units (which would make sense - the car has HKS piping and actuators). Some others on this forum have noted that HKS turbos squeal but I have no idea if this is true or not. The car also has a Greddy oil management system. It sucks because I'm pretty good at looking after it.
Any advice on what to do? ;)
Sig.
https://www.sau.com.au/forums/topic/201478-turbo-squealing/
My stock turbo started making a squealing noise on boost and when I took it off to replace it there were small chunks missing from the compressor fan fins.
Im pretty sure that if youre getting a loud squeal it does mean that the turbo is on its way out... Not sure about HKS ones though.
https://www.sau.com.au/forums/topic/201478-turbo-squealing/#findComment-3580673
Leaking exhaust manifold.
its either the manifold its self or where the turbo bolts onto the manifold..
Check to see if all Manifold studs are there, esspecially on the rear.
And look to see if there is any carbon around the manifold..
had Same prob, common thing sposably..
https://www.sau.com.au/forums/topic/201478-turbo-squealing/#findComment-3581200
turbos don't squeal unless they're really happy and they're girl turbos.
seriously; have a look at the turbos with a torch, it will either say Garrett or HKS on the inlet side but neither should squeal. who did the overhaul?
does it come and go with revs in neutral, revs with little / no boost or revs with load / boost. exhaust leak should make a ticking noise.
if it's easy to make it happen listen under the bonnet so you can try and pinpont the location of the noise. hopefully they can be more precise than 'could be a dying turbo' as you're unlikely to want to take the the turbos off on that basis.
cheers
https://www.sau.com.au/forums/topic/201478-turbo-squealing/#findComment-3581307
thanks heaps for all the great suggestions guys - it sounds more like a whistle than a zing. Like when people watch fireworks. Oooooh! Pitch gets higher as you accelerate. I think it only really starts at about 2100 rpm.
i do hear a ticking sound at idle, with the bonnet up.
i'll have another look at it in daylight tomorrow.
https://www.sau.com.au/forums/topic/201478-turbo-squealing/#findComment-3581821
If they're newish HKS's or overhauled, then I doubt the comp wheels rubbing on the front cover.
Considering they were recently taken off the car, i would say that its an exhaust leak, did you (or they) use the old gaskets?? Ill put 100 internet dollars on it.
https://www.sau.com.au/forums/topic/201478-turbo-squealing/#findComment-3581825
100 internet dollars lol nice :D
please do tell us what the problem ends up being i have a problem car so when it happens to me id like to know what it is.
https://www.sau.com.au/forums/topic/201478-turbo-squealing/#findComment-3582025
hi guys,
ok, i think i can see one of the turbos (one side, at least) at it says "Garrett" on it. Can't see anything saying HKS, but the guy at Autotech was pretty convinced, though?
The workshop was Precision Turbochargers. 2x Turbo's overhaul, 2x steel wheels fitted, $1600.
The 'ticking' i can hear in the engine bay is actually more of a tapping, on the left side of the head, rather than the turbo side. The tapping seems to stop momentarily when i rev it.
christ i wish i knew what i was doing.
https://www.sau.com.au/forums/topic/201478-turbo-squealing/#findComment-3583414
RB26s have noisy top ends, the inj and solid lifters see to that.
HKS turbos have HKS in raised lettering on the intake ie silver housing on the side facing the front of the car. if they were HKS turbos and were 'steel wheeled' that's unusual as they have steel wheels anyway, unless they were damaged. if the housing says garret it sounds like maybe they've just done a steel wheel coversion on the stockers.
did autotech suggest anything other than a turbo? i'd hope they could be more specific, or are they just as confused? try taking it to Trojan, John is a cluey guy.
don't worry too much, engines have all sorts of weird ass ways to make noises. have a look at your accessories, the ps pump can make bad noises when low on oil, and the a/c comp sounds like a meat grinder if it needs gas or it's bearings are shot.
also engine fan clutches make strange noises when they let go, alternatively see if the fan is hitting anything when it turns.
https://www.sau.com.au/forums/topic/201478-turbo-squealing/#findComment-3583525
oh... my 25/30 kind of does and its almost brand new, but its more a whine than anything, a sequel is either exhaust manifold crack or leak, if it is the turbo then well not so good, take it to trojan for a second look!!!
https://www.sau.com.au/forums/topic/201478-turbo-squealing/#findComment-3583601
agreed... if the turbos are still performing well and not dropping much boost, then i'd say this is your problem. happened to me as well.
https://www.sau.com.au/forums/topic/201478-turbo-squealing/#findComment-3593375
hi guys,
i haven't yet taken her in to be looked at (work issues). but i'm coming round to the idea of a leak.
when i dropped it off, my two complaints were that:
since they'd tuned my new powerfc, the car had been running very rich (400 kms per tank, whether i floor it or drive like a granny - 520kms per tank with my old mines computer). he said the original tune had been fine, something else must be doing it.
second, at idle, she frequently 'hunts' (revs by itself).
so i guess it could be a leak somewhere?
https://www.sau.com.au/forums/topic/201478-turbo-squealing/#findComment-3593488
sounds like your BOV might be giving you some strife. its a common problem, nothing to be too worried about. i dont know the reasons behind it happening, but it does happen. Bullet32 will know the answer... (he saved my baby!)
https://www.sau.com.au/forums/topic/201478-turbo-squealing/#findComment-3594301
tapping noise would be ur tappets. http://en.wikipedia.org/wiki/Tappet
https://www.sau.com.au/forums/topic/201478-turbo-squealing/#findComment-3594666
    • Be more active mate.. , not taking the piss ❤️, your long term health will love you for it I would think something like a kettle bell or 2 laying around in areas you go past during the day would be awesome for ADHD.... "Oh look, a kettlebell", and exercise helps your brain health as well My mates son was a bit of a problem child, diagnosed wirh ADHD, and some other things that had his brain occasionally doing loops, until we got him into a training program, the difference after he started training was amazing, he had more focus, and his fitness levels exploded, it is like he is a totally different kid to be around Brain chemistry something something Stay fit stay strong mate
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
