ok, so i had a missfire just like everyone else...
time for new coils...splitfires...but wait i thought....
my coils all meter out fine, there is no visible cracks or signes of cracking or heat marks or anything...they look perfect! and the philosophy of 'looks like shit, smells like shit, feels like shit...must be shit' concept always reigns true to me...so...
i actually stopped and thought about this for a while...and passed the issue to a electronics and power genuis i know...
we thought about the manufacturing method of the coilpacks and what they are all about...
Nissan coilpack are atransformer coil. the metal you see on the outside of them is actually a whole series of plates that run through the coilpack and form the centre of the transformer...meaning there is a shitload of wire wrapped around that core inside the pack. once the pack has been made, resin is poured in the plastic box and is cured. this resin can break down over time (as is happening) and a crack can actually form inside from the centre that is completely invisible (obviously as its inside the coil, duh)
now the rails that the coilpacks live on is grounded, and if the paint where the bolts that hold the coilpack onto the rail has come off, then the core/plates are grounded too...and if you have a crack on the inside of the coil in the resin then the spark will never leave the coil that it is charged in..it will just ground straight away!!!
so how do we fix this (and this works):
i have used M10 fiber washers on either side of the M8 bolts that hold the two coilpack rails in...and i have also put heat shrink around the tops half of the M8 bolt so that it is completly insulated. this has worked perfectly and i have just run the car up on the dyno will full load and no breakup!!!
this has made my day! i saved $500 and will potentially have changed the skyline world forever!
i will post some diagrames and pictures soon...i there are also some refinements to this concept i have come up with to further to make it more failsafe...
for the record, my packs are not taped up as i could see no external cracks...
UPDATE: sorry guys but this hasnt worked long term...im sorry i jumped the gun but i was so excited...
https://www.sau.com.au/forums/topic/201481-revolutionary-coilpack-fix/
the washers were bought from a Reece plumbing store...they are a fiber washer...
howver be aware that as part of my ongoing research into this fix, this washer is not the best 'permanent' solution. i am looking for a washer made from a material called mica. this is completly heat and chemical resistant. finding M8 and M4 mica washers is prooving hard but once i do i will let everyone know!
actually yes they would work great!
BUT...
it doenst matter anymore as this hasnt fixed the problem long term and while it work yesterday on the the dyno today it is breaking up. so splitfires for me!
BUT...
WAFFLES DON`T DO IT :P DUDE PLEASE TRY THIS .OK I have sparyed my coil pack`s with CRC URETHAN SEAL COAT.THIS IS USED TO COAT WINDING`S ON ELECTRIC MOTOR`S,This seal`s them .I have mine sprayed for some 6 month`s & have had no problem`s.just give coil pack good clearn with scotch bright,then good wipe with prepsol,hang & spray(read disstruction`s) :P shakewell,4 or 5 coat`s don`t go :rofl: darft let them dry,may be one :/ a day.you can spray what colour you like then BLUE.Even get in touch with the OTHERSIDE :wacko: dude,see how you go,GOOD LUCK DUDE LET US KNOW THE BOBBY MOORE ,cheer`s chuckie. ps all my photo`s are big have reset camera, to take some more.
ok well its too late for the purchase and i have them in right now, but....
i will try what you say and then in stall the old ones.....
i beleive that unless we try thins then we dont ever push the boundries of life and while this idea of mine failed, i like your and will persist!
i'll find this paint as it sounds so perfect.
thankyou for the heads up!
at least i can take my time with the old coils and still drive me car....
with new plugs and the coils though, my car went from 188rwkw to 220rwkw as it has allowed the tune to keep progressing... i think we'll get 250 out of her yet and keep the economy!
WAFFLES JUST SOME PHOTO`S OF SPARY CAN OK GOOD LUCK DUDE CHEER`S chuckiepost-36964-1200549995_thumb.jpgpost-36964-1200550147_thumb.jpgpost-36964-1200550450_thumb.jpg
Stripped mine all apart and cleaned them down with acetone the coated them twice with a good quality polyester resin ! No misfire for around a year. Very easy to do and works fine as the polyester resin seaps into the cracks catylises and is stable up to about 600 degrees C !
I had cracks in my coils that could only be seen by a camera in macro mode. In otherwords you would have needed a magnifying glass to view the beginning of the crack.
My coils were extremely bad popping and farting with anything over 10psi. I siliconed them up liberally and they have been good up to ~19psi but began experiencing the onset of missfire at the higher rpms.
So still good for 1bar and 268rwkw but not much more.
WELL GIVE THEM A GOOD CLEAN & TRY THIS ONE OUT SEE HOW YOU GO ????????,THIS COULD BE YOUR LUCKYDAY CUBES :blink: ,I HAD SOME PROBLEM `S I COULD NOT SEE ANY CRACK`S,LOOKED AT NIGHT NOTHING,THIS HAS SORTED MY COIL`S OUT :cool: GREAT JOB,1 THING I WILL SAY YOU CAN HAVE ANY COLOUR YOU LIKE :D .NOT THAT SHITTY SILICONE LOOK :) CHEER`S CHUCKIE
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 👍
    • Its sort of street but got used for circuit sprints on account of I never drive it on the road because I dont have the time to spare. So it usage was sits around for months at a time then gets driven either 50 or 250 kms to the track followed by 20 laps followed by 50 or 250kms home followed by stuck in the shed until next time. So yeah neither fish nor fowl. Just dont want to break it on the track as a preference. Hence the fairly short sensor/mod list. Probably more worried about it pinging itself to destruction more so than anything oil related.
