hey guys..... there is this dam noise that has only started about a day or so ago... i was driving home at night... and noticed that the car when it hits full boost (1 bar) a wistling, screeching kind of noise is comin from the turbo area... it is most noticable when u boot it in 2nd...and gets less and less as the gears go by... i checked for leaks and so forth.... and had a look in the front of the turbine to see if the props are all tight and everything seems fine... its a really weird noise... and i am sure its either the turbo or the external gate.... but stumped/... its a r33 with a t04e garret turbo high mounted..with all the bolt on mods.... any help would be appreciated... but this sound has me sketching!!!!!... thanks guys
https://www.sau.com.au/forums/topic/201490-wtf-is-that-noise/
gaskets?
between engine and manifold
manifold and turbo
turbo and dum pipe.
see if all the bolts to those are tight (or even still there)
hey dude..cheers for the reply.... ummm the gasket for the engine to manifold is almost brand new and just had all the exaust studs replaced with stronger lock tight bolt... and that there is all lookin sweet... all the bolts are there and seem to be tightened up beautifully.... its got me stumped and im freakin it.... lol... n e other ideas??... thanx man
anyone with n e ideas what so ever.... ??... all bolts are tight...external astegate is tightened up and all... the only thing that looks wrong is an oil leak from the side of the engine (its tiny tiny tiny) and i dont think that would have n e thin to do weith it.... cause its been there for alot longer than the noise...
sounds like its an air leak. could be gaskets. Also try checking all the silicon hose joiners are tight. u say the exhaust gasket has been recently replaced, the mechanic could have been lazy and not tightened everything up
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
