Hey guys, had my car dyno's was expecting a little more but anywayz, though maybe we could have a discussion on here =D
RB25DET
GReddy Intake
80mm TB
FMIC
3" intake pipe
BOV
Billet fuel rail
550cc Inj
Bosche 910 pump
surge tank
Sard Reg
high flow fttings etc
GT30R .82r
kazama manifold
44mm Gate
3" system
splitfire coils
EMS 4424 stinger
Auto box, had a manual valve body but box i believe was slipping at time of tune
330rwhp @ 16.5psi
think something is wrong? or do i need to retune once i get my properly built box back from top quality transmissions?
https://www.sau.com.au/forums/topic/201493-rb25-power-output-low-or-avergae/
I wouldn't be trying for too much more than that out of a standard? 25. There are some that can reach the high 300's & maybe a bit over, but it is risky & it depends how it's driven.
From what I read, I was under the impression that by 300rwhp the RB25 would be on a knife's edge for reliability....
Hmmm....
i have been running 335rwhp now for over 6months without a problem, (most likely longer just cant remember), also ive taken it to the track more than once and had a full drift pract day at the track without a problem :)
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
