  • Replies 80
What a day.
Well the ankle held up ok... much better than my tyres.
Had a ball, got to drive a type R integra and also passenge in a 205 GTI.
Had some fun in my car, believe that pete has some footage of this. Played fun and games with a "It is you job to pass me, why should I move over for you" VS/VX? SS crummy dore with SUE number plates... what a typical crummy dore driver. aparently he lives in the mountains too... hmmm
Did some nice laps early, HOW PACKED was group C. I think I overtook 2 cars a minute in the first session... was good though.
Had a ball all day... but wasn't it long, went home and had one more beer... which took ages to drink and fell asleep.
Good to meet all the newby's, all were great people and I hope to see you all again. As for the crazy regulars, a pleasure to spread rubber with you as always.
Untill the next day,
Drive carefully, don't speed, and protect your rubber... you'll need next time!!!
Dan.
Originally posted by ManNGolf
Hey Julian, I know u miss the UK flavour in cars but ur not allowed to have the MKI bit in ur profile......its a gts-t "series I" mate........i'm the only one here who can make reference to "MKI" ......hehehhehe jk!!!!
Sorted I've sold the MK I and got a Series I now :D
Guest MattY
Yeah was a really fun day. It was nice meeting some of you guys, damn there were alot of skylines out there : ) Hats off to the guy with the cam corder mounted in the rear. Im definately gonna try something similar for the next track day. Mebbe even one in the foot well. HAerhae.
Look forward to driving with u guys again. Provided i have rubber for the s15 to sit on : )
Anyone got any pics to post? lap times?
Whilst dumping my video 8 down to VCR, i timed some of my laps. My best was a high 2.01. Im wrapped considering i run std boost.
No doubt Eastern rewards good suspension more than Wakefield.
Took the turbo off Friday night, the noise was a blown exhaust housing gasket. $50.00 gasket later back on the road without the Kombi exhaust note.
Errrr... are you kidding? Wakefield is a much more suspension oriented track than Eastern Creek...
EC is a more big HP track... Wider turns, the straight is double the length of Wakefield's straight...
Yeh maybe, but Wakefiled is very stop go with two fast corners that are over before they started, (about 70 degree turns).
I was thinking Eastern with its high speed sweepers and third gear corners that my car suited it a little better.
I agree that with big HP you are going to be a lot quicker, but at Wakefield i struggle to be 1.5 seconds quicker than a friends 200sx which is quicker in a straight line, but at Eastern i simply drove away from him.
Food for thought anyway, the end result is its finally time for some extra hp
Hey guys, these two tracks are two different circuits. many people will have differen ideas on which is better with what set-up and so on. this is only gonna start a huge argument.
My surgestion. drive at both and then decide for yourself what feels right.
Hmmmm... Okay... The 200SX handles a whole lot better than an R33 Skyline, both having equal amounts of work done to the handling...
So the your skyline eats the 200SX for breakfast on EC, but is hardly any quicker at Wakefield?
Doesn't that suggest that the 200SX's superior handling and suspension is more beneficial at Wakefield?
Majanal... I'm not arguing here, just having a friendly discussion on how different setups benefit on different tracks...
Afterall... Arguing is like the Special Olympics... Even if you win you're still retarted :cool: (Admins can feel free to edit that out if they feel the need :D)
Not arguing either, but one of the benefits of these types of days is to see where others cars are strong, and where yours is lacking.
My friends 200SX has King Springs, with Koni Rear shocks (Rear only). It has exhaust filter, clutch and boost.
My car an R32, has a complete Whitleine susp kit with cat back exhaust and filter, clutch & flywheel, good pads and fluid.
In a straight line his car boosts quicker and is comfortably quicker than my car. No 180km/h speed limiter either.
The fact that during acceleration and top end his car is quicker, but my car handles and stops a little bit better suggests that at EC my car works better than his, and at Wakefield his car is almost as quick (his hp advantage brings him closer)?????
At the end of the day neither of our cars are that special, but we make do with what is available to us.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
