Hi all,
Just wondering if anyone can tell me, have searched and seen pics, but can't be too sure. The Apexi Super Suction D-Jetro obviously removes the AFM's from the equation, does it basically replace piping (stock rubber ones etc) from the Air Filters ALL the way to the turbos?
And does it comes with brackets to hold the pod filters in place etc?
Also! While I have your attention. I am looking for hard pipes (I think might be HKS) that replace the "Twin Turbo" Pipe. There is nothing wrong with the stock pipe, it just sits too high on the RB30 and can't put the strut brace on.. so looking for something that sits lower.. have seen pics, but searched and searched and can't seem to find it. (probably can't fit this AND the Apexi setup I'll bet)
Its either this, or fab it from ground up I guess..
Edited by R32 TT
https://www.sau.com.au/forums/topic/201507-apexi-super-suction-d-jetro/
you might be able to use the ztune style hard pipe kit
its on www.nengun.com and i think the super suction kit or power intake includes the afms, the pipes and brakets etc
its a complete kit - around $500 ish for the djetro version? nengun has it as well
  • 1 month later...
Well I ordered myself the Apexi Super Suction Kit (D-Jetro) and it has been held up, but a mate has had his arrive and unfortunately it does NOT replace the large rubber convoluted tube (with the big spring inside it) that goes to the rear turbo.. :)
So I now have every hard pipe except for this one.. Looks like the HKS Premium Suction kit does have it, but it is only listed for R33 and R34 GT-R's , here is a picture of it just below the Twin Turbo Pipe...
Does anyone know if these kits will also fit an R32 GT-R - or does anyone know what alternatives there are for replacing this pipe other than getting one custom made? HKS kit is about $500... which sucks (no pun) if I only really need this one pipe...
This isn't $200/hour Japland :)
My advice is, unless you REALLY want a name brand part, to have it fab'd by someone experienced.
Pre-made stuff certainly has its place, but it just might be too much of a nightmare with your 3L setup.
Get a piece of ally plate PC milled with what ever you would like on it "Matt Hat Performance" or somthang, tacked where the "Twin Turbo" usually is.
intercooler pipe ftw
umm.. okkk.... (?)
As a possibility, maybe get kermit to make you up one? Thread in wa section.
Ah, good man, thanks for that - I found the thread and this looks like a good avenue!
This isn't $200/hour Japland :D
Yep I definitely don't require a name badge on there. Only mentioning these things because sometimes these tricky bends and tight spots can be a lot of dicking around - which equals time.. which translates to money.. so in some cases the off the shelf HKS part is actually good value. All comes down the the fabricator of course, Kermit sounds like a good guy to meet though.
Hmm... Matt Hat Performance eh....? You sure people won't laugh...? :P
Cheers for the replies guys - I'll add pics of the result when I get there.
Ok well the kit has arrived, so thought I would take a photo of its contents as I would have liked to have seen what was in it before I bought it, so maybe this will help out anyone thinking of buying this kit..
Note the bigger bendy pipe goes all the way to the front turbo, the shorter pipe only goes to the large black convoluted factory tube - which then goes to the Turbo.. (I was hoping the kit replaced this too..)
Also in the kit are Silicon tube, hose clamps and brackets which secure the pod filters so they can't move around.
Note also this is the D-Jetro version, so it is designed to completed do away with the AFM's.
Hope this info is helpful.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
