hey everyone, decided its come to a time to move on as iv fell in love with another car but for people who dont know i built this from ground up,
item: r32 gtst skyline
body has done 118,000kms motor has done 90,000
RB20DET - 5 Speed Manual
Chipped ECU
GTR front mount
Exeddy heavy duty clutch
AFM
Steel intake piping
Pod filter
Bleed valve
3 inch stainless dump pipe with screamer
3 inch front pipe
3 1/2 straight pipe
Eibach Potenza coilovers front 11kg
Kyb springs in rear
D-Project adjustable castor rods
D-Project adjustable camber arms
Greddy catch can
Hicas lockbar
GTR fuel pump
Short shifter
Standard LSD
Cusco front strut brace
HKS Super sequential blow off vave
Bride seat (will come with, for right price)
Fire extinguisher
Defi boost gauge
GTR steering wheel
Turbo timer
Stripped interior and sound deadening
Safety 21 6 Point Roll cage (side intrusion bars not fitted but will be included)
Standard Gtst Front bar,skirts and pods
Flared front guards
Paint : Matt black
Spoiler removed
Black Drift Teks +25 offset 17 x 9
Steer Tyres: Intensa Sava's 235/45/17
and a pair of stocko r33's
bad bits:
-speedo cable broke about 500 - 1000km ago
- paint and panel isnt the best
does not come with rego or rwc....
10k!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!ONO!!!!!!!!!!!!!!!
no low ballers please
PM ME !!!!!!!!!!!!!!!!!!
PLEASE NOTE THESE PICTURES ARE FROM A MONTH OR TWO AGO CAR SITS ALOT LOWER NOW AND HAS DIFFERENT RIMS
any more pics just ask
thanks
josh
https://www.sau.com.au/forums/topic/201525-r32-skyline-4-saleswap/
OMG. This car is so shit.... I say that ONLY because I love it and I don't want Josh to sell it :D Gonna miss seeing it everyday up the street :P Sounds phat with straight pipe, screamer & SSQ BOV. Slides nicely too :(
Good luck with the sale man, and whoever buys this is getting one very phat pig :(
    • I am being real ocd and do not want to make amy mistakes so appreciate all help provided. I am overly cautious so asking for opinion even if i know the answer   few questions,   1.re tensioner, should spring be greased lightly?    2.tensioner has two washers , one pressure washer and other has recessed/ seat. I am going to put the recessed one facing tensioner where edges are cut out and pressure washer on top   3. my car has custom triger kit sold few years ago by guy who initially built the engine. I moved the crank gear and it moved in and out easy, only way to remove belt is to slide the crankshaft gear forward which I did. I have seen these being very tough to move , anything to do with my woodruff key?   it has a crank sensor shown in purple which I assume reads from the 12 teeth position mounted to the crankcase gear   4. timing belt doesn’t have arrow stating front or back just a arrow which I think is direction of rotation . Do you agree?   5.i figured out why my crankcase cover was worn as there was no washer installed over the crankcase cover before the harmonic balancer was put in place. It is missing, anyone knows the part number? It looks like this https://justjap.com/products/genuine-nissan-crankshaft-timing-gear-rear-plate-washer-nissan-s13-ca18-a31-r32-rb20-r33-r34-c33-c34-c35-rb25?currency=USD   https://tinypic.host/image/IMG-4535.382Zy2 https://tinypic.host/image/IMG-4537.382dSz https://tinypic.host/image/IMG-4534.382q4U
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
