Hey guys,
I bought a pair of used R34 xenon headlights not too long ago and ive found that the right hand headlight is higher than the left. Does anyone know how i can adjust the headlights so they are at the same height? (I already tried electrically adjusting them via the switch inside the cabin).
Any help appreciated.
Thanks in advance.
Alan.
ps. Sorry if this has been covered already.
https://www.sau.com.au/forums/topic/201531-adjusting-r34-xenon-headlights/
I'm not too sure if R34's have these, but try adjusting the knobs behind the headlight housing. Should be 2 hexagonal screws. One will control up and down, while the other side to side. Not too sure if R34's have these though because they've got the electronic one.
    • yeah, there's a country that recently started importing Skylines, I blame them.
