Hi everyone,
It appears that the clunk from the rear of the car is the driveshaft, there is wear on the driver's side rear of the car, the passenger side appears to be ok.
The diff makes a few noises but its not the clunking noise that happens on gear changes
There is a guy selling the CV joints on ebay which are the most likely culprit for the noise:
http://cgi.ebay.com.au/Nissan-Skyline-R32-...1QQcmdZViewItem
Has anyone bought off ebay?
Is that overpriced?
Would you recommend replacing the CV joints for a clunking driveshaft?
Has anyone here done it before?
Regards,
Gareth
  • Like 1
https://www.sau.com.au/forums/topic/201547-clunking-noise-from-driveshaft/
i dont know about the cv joints but i had that problem with my standard diff and ive now gone to a mechanical one.
changing the half shafts is a diff out job. im not sure if theres an easier way without taking the diff out.
The diff has been removed at least twice now, its been rebuilt and I don't think its the problem ;).
However, the half shaft if pushed by hand with some force makes a soft "clunk" when the car is jacked up.
When driving its obviously a lot louder and I've read threads about other people complaining about similar noises, I was hoping it was the same issue and other people had fixed it before :banana:.
Oh, and GTR diffs are mechanical :banana:
yeah a reconditioned driveshaft wil lbe $75-$150 depending on how much they need to change in the cv joints, there are 2 in each driveshaft as well as the 2 boots. they ar ea bit of a pain to get out so it could add up to say 400-500 if you need a mechanic to do it all for you
I have got the same problem in my 32 at the moment, clunking in the back... And it is the drive shafts (inside CV is dead) Not hard to change. But there is a big nut on the end of the drive shaft in the hub, which can prove to be a real bastard to get undone.
Skid
Skid
Hehe, we stripped a socket (not the bolt!) trying to remove the diff bolts. We were using a large jack handle as an extension ;)
Did you replace the CV yourself or did someone do it for you?
Where did you buy the CV from? I've seen the ones on Ebay but nowhere else, just search for "r33 cv joint"
Regards,
Gareth
any mechanic can organise the work for you, but very few of them have the proper joint seperators so they will ship them to a specialist - would still be same day turn around through
  • 3 months later...
Haven't done this (yet) but I've found what was making the clunking worse was that the driveshaft bolts near the diff were loose. One was basically out, another took a couple of turns and a few others were able to take a 1/2 turn and a couple were tight.
Definitely something to check, the car hasn't been on a hoist because of the bodykit so we hadn't noticed it and we were looking at the diff and half/shafts....
There is a little play in the system so that might be part of the clunking.
They have been tightened up now and its a little better, enough to not concern me anymore, I'm kinda used to it now :(
  • Like 1
how much did it costs to rebuild a diff ?
cheers
The diff has been removed at least twice now, its been rebuilt and I don't think its the problem :blink: .
When driving its obviously a lot louder and I've read threads about other people complaining about similar noises, I was hoping it was the same issue and other people had fixed it before :( .
Oh, and GTR diffs are mechanical :(
cheers
It was done by a friend of a friend so very little, however it didn't change the clunking or diff whine sounds, when opened up it looked fine, I've got a thread with many pictures on the forums.
It did however stop it from making a lot of noise when reversing up the driveway (due to removing some pretension), it does still make sound when turning corners on the street, especially when the diff is cold.
sounds like a flogged bush, one question, have you lot lowered your cars???
Interesting....yes its lowered, the Japanese suspension had the front bar 85mm off the ground, or somewhere around 335 or 345mm centre of wheel to guard on the front.
Its been raised to 355mm centre of wheel to guard (roughly, I haven't measured it for quite a while), and the rear is 10mm higher than the front.
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
