  • Replies 41
Posted Images
lol. Maybe you should just disconnect the hand controller. Then you will solve your knocking. Just probably paranoid cause your monitoring it all the time.
Oh yeah be sure to keep your eyes on the road too.
So your going to get a de-cat pipe, you'll get some nice flames :blink:
https://www.sau.com.au/forums/topic/201554-dyno/page/2/#findComment-3586470
hmmmmm i gotta pay for the members section ! hahah hmmm just a question top racing resolved the knocking issue by advancing the timing back to 13 instead of 18 so does that mean i lose power? the tuner said because my head gasket is too thin and when he advances the timing to 18 it will knock :D so in order to run more timing i need a thicker head gasket? hmmmm ahah .....lunjiao its not beign paranoid its my engine light it kept flashing when i chopped that v8 or the turbo ute lol my bro's like WTF is happening ur lights are going crazy ! hahahha so yeah looked at the controller and knock was like 80+ to 160+ so im like WOAH HOLY DAMN !!!
Cheers
Chi
Edited by Chi100188
https://www.sau.com.au/forums/topic/201554-dyno/page/2/#findComment-3587014
I don't think you would lose power. At least your engine will last longer though.
Just get a new turbo and other mods for more power =P then you can take it to the dyno day when ever that is.
But yeah i guess you didnt get too bad on the dyno.
https://www.sau.com.au/forums/topic/201554-dyno/page/2/#findComment-3591074
Less timing will make less power.
What your tuner was trying to say is, your compression is too high to run +18deg (btw he RETARDED your timing, not advanced it), a thicker headgasket will reduce compression slightly allowing you to wind more timing in. Less compression will also handle more boost but make less power off boost.
Your engine was originally NA wasn't it? this would explain the high compression, you will never be able to run as much boost or timing as a turbo engine as the compression ratio wasn't designed for it :P
Edited by bubba
https://www.sau.com.au/forums/topic/201554-dyno/page/2/#findComment-3593841
no this engine is Mitchy's engine and it was turbo originally....but was rebuilt apparently.......the tuner said the head gasket which was used may not be as thick or someshite :D hahah but yeah still goes pretty hard right now :blink: my NA engine is still at my mates house from the transformation
https://www.sau.com.au/forums/topic/201554-dyno/page/2/#findComment-3594407
