http://www.skylinesaustralia.com/forums/Re...l=steering+boot
boots from repco which cost $13.50 each. The part number is RRB033.
Depending on brand; My Castor rod bushes (superpro) cost $100~
$27 + $100~ = $140~ for parts
$360 for labour? im guessing wheel alignment done; $60~
So about $300 for labour?
I got camber, castor, steering rack bushes, subframe bushes & steering rack replaced for $300 labour..
hope that helps :D
Thanks Rekin
with the steering rack boots part number, are they for R32? or universal? how they fit to the car? cause one of the member on that thread said it not a very good fit???
also, where can i get that Castor rod bushes (superpro)?
cheers
Edited by subie
Im pretty sure the DIY is for a R32, they are the boots i bought for my R32, so there will be no problem for you.
Im not aware of how well they fit, got my suspension place to fit both steering rack boots for $30 labour. He didnt seem to mention any problems..
SuperPro is an australian bush company (http://superpro.com.au)
I got my Suspension workshop to supply and fit, but im pretty sure Supercheap Auto sell them.
I paid $50 each for genuine Nissan boots as I cbf screwing around with non-genuine generic items that need trimming etc.
Fitment was easy but took a while and setting the toe back by eye (counting threads).. was pretty close.. only 0.1mm out :D
I got my castor bushes through Brad at WA Suspensions and IIRC they were only ~$80, fitment and an alignment was nowhere near $500 either.
ok guys.. with the caster rod bushes .. should i get the after market (adjustable) caster rod and change the whole thing? or just changing the bushes? it an everyday car (never see track or drift)
also, I've got few quotes:
Pedders (local area): $450.00
- rubber boots $40 pair
- caster rod bushes $100 pair
- labour $220
- 4 wheels alignment $90
Luis drift Garage: total $340.00
- rubber boots $60 supplied and fitted
- KKR caster rod (adjsutable) $280 supplied and fitted
- then I have to do the wheels alignment else where
- gonna take me like 1.5 hours drive from my place to his
what u guys reckon?
cheers
hey ive got a cracked castor rod bush on my 32 and i just bought some adjustable castor rods from ISC Performance..there a trader on here..got em for like $180...im Getting new tyres soon so when they fit the tyres i'll get em to put the castor rods on too and get a wheel alignment
bugger if you were in vic i could help you out maybe someone from NSW can point you in the right direction.
its a pretty easy job if you wanna do it your self, theres plenty of "how to's" on these forums.
the difficult part would be getting the old bushes pushed out as u need a 10 ton press most suspension shops can do it though.
Luis drift Garage price is okay but 1.5h is a fair trek and you will still need an alignment, i dont see how they can work with suspension and not be able to do alignment.....
and pedders just suck.
  • 1 year later...
ive got a r33 gts-t series 2 and am changing over the steering boots. My original boots had 48059 marked on them. Not sure if this is correct as they were quite difficult to get off (i had to cut them off in the end) After reading on here i decided to get the universal boot, rrb 000
i have put the 2 boots together. as you can see the end diameter will not fit over the steering rack. i could cut the last few rings off which could work or is there a better option ??
You're supposed to cut them.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
