No problems mate. It's one of those things I want to do, just can't really justify it yet.
Plus it kind of worries me ordering parts from a bunch of numbers!
Hey Jase, yes the thought of ordering from those part numbers is abit of a worry, imagine it rocks up and its the wrong colour or something, i'd not be happy.
  • Replies 43
Yep that's exactly what I'm worried about.
I think I'll have to look into getting this FAST software myself..
Yeah, but even with Fast, you'd have to physically see the car whose VIN you're using to verify that the colour was the same... Actually, that gives me an idea: I hope there's a 260RS coming on the qld meet....
Good thinking Micah!
How many different coloured interiors are there?
I know in a series 2 the gunmetal grey plastic trims are slightly darker than a series 1
Micah,
The trim I have is out of a series 1 260rs, which would be the same as the series 1 RS4.
As far as I am aware, the parts that have been quoted for the console parts should for a series 1, as the people who have ordered them all own series 1 cars and have not complained about any colour differences.
I am the only series 2 owner that has converted on here, but luckly I picked up a s/hand series 2 console.
interesting point darrin, you got me thinking.
I have s1 converted with s2 manual parts and I spent some time starting at it today. Both the colour and pattern are very slightly different between the s1 bits and s2 bits- but you would never notice without staring and myself and no-one else have ever mentioned noticing it.
Guys don't worry about the part numbers in the thread. I was also worried (of course) so double checked them all and they were fine. I ordered directly from the list and got exactly what I needed. Also all parts are the same colour so nothing to worry about. The trim on the centre console does not match the s1 interior, not a problem for me because I retrimmed in leather.
Couldn't have put it better myself Duncan :rolleyes:
Took quite a bit or research on FAST, and a lot of triple checking to get the right numbers, and yes I was very anxious when I ordered the parts, but it all turned out sweet. And I'm glad other people have benefited.
As other people would know, there is only two interior colours available with the Stagea, the Z & J, so if your not sure, get your VIN FASTed.
  • 3 weeks later...
I have, i got the blank plate for the cup holders and the blank plate for the auto indicators on the dash. I had problems with stock not being available, but as soon as it was, it took 3 days to get to me from Japan.
Yeah I know, I saw your car after I ordered the parts. I don't need 4 cup holders in the front though, 2 is enough for me.
4 cup holders? :P I don't need 4 either..
If I use the part numbers in this thread will I get 4 cup holders?
the manual console has the cupholders in the console. the auto stageas has them popping out from under the climate control. if you leave the pop-out ones in, and install the manual centre console, you get 4.
    • The previous switchover point was 501mv. The stock value is like ~360. They now were idling at about ~880. The thing is, most people get a false lean condition. I am getting false rich conditions. This isn't a quirk of terminology, most cam upgraders get awful fuel economy because the O2's read false lean and add fuel - Mine are attempting to aggressively subtract fuel.
    • So... the whole idea was to upgrade the power of the motor from stock. The motor I bought with the gearbox had 'some' stuff done to it in the past, but it wasn't as well thought out/what I had wanted to do. The stock heads typically are a big restriction on LS's and need porting to unlock quite a lot of power. You can then go a bit silly with aftermarket castings to get more, aftermarket intake manifolds for a little more, and then porting those for more. <- We are here. Nobody in Australia really goes down this path (for some reason). It might* make 3kw or something more than doing things the tried and true path for 10X the cost. So that's probably why - I wouldn't even recommend it to people, the money was and is likely better spent on just CNC'ing the stock heads and putting a 6.3L stroker kit in. I didn't want to go down the 'normal' path and then think: But if I'd just done a bit more - I could have had a slightly better result. I assumed the heads were running out of flow and it always annoyed me - Turns out the previous installer advanced the cam 6 degrees so this is likely why it was coming on earlier and running out of puff earlier than advertised. The body panels were just lack of planning/no information on this anywhere on the internet and the fact they came out different was annoying. From test fitting the guard it appears I could have gotten away with GTR guards only, but I got the bonnet and raisers and everything else as well for a pretty decent package deal.
    • So you had a car that by all accounts drove well and survived track days, and that was looking great after months of being stuck at a paint shop. Some might call that a finished project. But you decided this is not quite right. So now the car does not run anymore. And the engine doesn't fit anymore. And the body parts don't match anymore. But, this is progress somehow. Greg, I think your subconscious does not like you and does not want you to drive this car. (I know I know, this whole escalation was not intended, but man, what a rollercoaster)
    • Yeah, but the narrowband is truly narrowband. So you take it out of the linear zone and it is effectively nonsense. And that linear zone is so literally narrow, that nonsense is not very far away. Unless they are flicking back and forth across the stoich point, for real, under actual control, they can't be trusted for anything except entertainment value.
