No problems mate. It's one of those things I want to do, just can't really justify it yet.
Plus it kind of worries me ordering parts from a bunch of numbers!
Hey Jase, yes the thought of ordering from those part numbers is abit of a worry, imagine it rocks up and its the wrong colour or something, i'd not be happy.
  • Replies 43
Yep that's exactly what I'm worried about.
I think I'll have to look into getting this FAST software myself..
Yeah, but even with Fast, you'd have to physically see the car whose VIN you're using to verify that the colour was the same... Actually, that gives me an idea: I hope there's a 260RS coming on the qld meet....
Good thinking Micah!
How many different coloured interiors are there?
I know in a series 2 the gunmetal grey plastic trims are slightly darker than a series 1
Micah,
The trim I have is out of a series 1 260rs, which would be the same as the series 1 RS4.
As far as I am aware, the parts that have been quoted for the console parts should for a series 1, as the people who have ordered them all own series 1 cars and have not complained about any colour differences.
I am the only series 2 owner that has converted on here, but luckly I picked up a s/hand series 2 console.
interesting point darrin, you got me thinking.
I have s1 converted with s2 manual parts and I spent some time starting at it today. Both the colour and pattern are very slightly different between the s1 bits and s2 bits- but you would never notice without staring and myself and no-one else have ever mentioned noticing it.
Guys don't worry about the part numbers in the thread. I was also worried (of course) so double checked them all and they were fine. I ordered directly from the list and got exactly what I needed. Also all parts are the same colour so nothing to worry about. The trim on the centre console does not match the s1 interior, not a problem for me because I retrimmed in leather.
Couldn't have put it better myself Duncan :rolleyes:
Took quite a bit or research on FAST, and a lot of triple checking to get the right numbers, and yes I was very anxious when I ordered the parts, but it all turned out sweet. And I'm glad other people have benefited.
As other people would know, there is only two interior colours available with the Stagea, the Z & J, so if your not sure, get your VIN FASTed.
  • 3 weeks later...
I have, i got the blank plate for the cup holders and the blank plate for the auto indicators on the dash. I had problems with stock not being available, but as soon as it was, it took 3 days to get to me from Japan.
Yeah I know, I saw your car after I ordered the parts. I don't need 4 cup holders in the front though, 2 is enough for me.
4 cup holders? :P I don't need 4 either..
If I use the part numbers in this thread will I get 4 cup holders?
the manual console has the cupholders in the console. the auto stageas has them popping out from under the climate control. if you leave the pop-out ones in, and install the manual centre console, you get 4.
    • Yeah they charge a little extra for mods , last year I noted no mods but I did have an exhaust fitted after that so  better to let them know cause these kinds of things can cause the policy to be void if you ever need to claim.
    • Hello, just just bought an 1999 enr34 with a stock rb25neo and I'm looking to upgrade the engine to 500whp I know some basic things but wondering if there are things I'll need to do to upgrade the stock block and all the bits and pieces to achieve this.
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 馃槄
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 馃珷
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
