I have a friend who has been building a car - an R31 Skyline, Rb30E 5spd. He uses coilovers from an s13 and some steering control arms etc from an S13 aswell. Trying to track down a stiffer rear swaybar.
Car runs extractors from the wreckers and a 2.5" exhaust, autobarn heavy duty clutch, Pod with CAI, new leads and plugs. Diff is a weld job, is the only dodgy part.
Was a cheap car to build (about$2k, its no D1 car but its tidy and registered) and makes enough power. Should be taking it out soon hey.
https://www.sau.com.au/forums/topic/201566-na-drifters/#findComment-3581890
completely stock rb30e apart from extractors, exhaust and a pod filter, never misses a beat :D
exedy hd clutch, minispooled 3.9 diff
s13 front coilover conversion with jic 9kg fronts, s13 tie rod adapters, adjustable castor rods
rear is s13 7kg teins with cusco hr31 top hats (bolt in perfect then)
whiteline swaybars front and back, and adjustable panhard rod
got some r32 front brakes on for good measure
heaps of other small shit, but its certainly not a bad car to slide considering how much it cost. i drive it every day too
non turbos great for archerfeild, will be going there again this wed. it struggles at QR though, but its all about the clutch kick
https://www.sau.com.au/forums/topic/201566-na-drifters/#findComment-3581908
some sliding pics
rb30s are pretty good drift motors mainly because they are cheap as, but also because they have great midrange. unlike a rb20 you can rev it to 3k and drop the clutch and get wheelspin. only shit bit is they have no top end, dont rev hard and have a gay limiter
Edited by racsov500
https://www.sau.com.au/forums/topic/201566-na-drifters/#findComment-3581912
now i have to get a photo will take one 2morrow after work and post her up :)
mines completly stock besides an apexi pod and hopefully the gtst axles and viscous diff will go in ok this wednesday...fingers crossed :D
Edited by Caza
https://www.sau.com.au/forums/topic/201566-na-drifters/#findComment-3581914
nice work guys.
nick, i agree QR is a very power demanding track. even for circuit work you need a fair bit of power to push through the corners.
i do a little bit of motorkhana stuff and i agree the clutch does cop a fair bit of abuse, but contrary to what everyone says about having buckets of power to 'powerslide' a corner, i have found suspension setup and technique is more important.
https://www.sau.com.au/forums/topic/201566-na-drifters/#findComment-3581932
I been pondering about selling my GTS4 and buying a boro S13 for drift/girp application..
I care too much about my gts4 to take the risk of tire walls etc. etc. etc. So I ifugre.. if I dont care so much about it.. I could go balls to the wall..
Any idea?.. should I take the leap?
https://www.sau.com.au/forums/topic/201566-na-drifters/#findComment-3585404
i do what i can with an auto n/a 33.. im so considering selling to get a manual of something.. so much better but ill lose so much money.
only mods on my car are extractors, 2.25" exhaust, pod and working on my CAI, need an LSD :< and some better springs its like a boat atm
https://www.sau.com.au/forums/topic/201566-na-drifters/#findComment-3585580
they are 235's and not on belts but they resemble some sort of home made drag slick.
i should really replace them but.. im poor :blink:
try to make tyres a priority... they are the only thing keeping you on the road regardless of how much/little power you make. federal 595 is a well priced good performing tyre, check em out.
https://www.sau.com.au/forums/topic/201566-na-drifters/#findComment-3594568
    • Yeah, the latter. No diff should have a centre replaced without checking clearances because its unlikely to be the same as whatever came out. Not that that stops most people just checking a new centre in
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
