Hi Guys,
I've got an R34, and would like to have the centre console (cheap shitty black material) re coated.
Can anyone recommend anywhere to have this done? I live on the northern beaches and would prefer somewhere local if possible.
Thanks
https://www.sau.com.au/forums/topic/201597-console-recoating/
I'm going to get mine painted properly by Louie at Xclusive Colours. I've seen another car he has done like this (Malcolm's mega clean R33, was in HPI recently) and it looks good. I think he uses a satin kind of finish so it doesn't look home painted like people do.
Its easy to get car body paint look..
Drop it in some metho, bath it with a scouring sponge or somthing similar until all the old paint is removed, all is important!!
Then sand back with 1500 grit paper to remove most scatches you made.
Hit it with a Light coat of colour youd like, just buy body spray paint.
Then sand back with 2000grit
Then hit with heavier coat, then sand back again with water and 2000
Hit with heavyish coat but not full heavy, again sand back until smooth.
You may wish to apply a last coat now.
Clear mild coat and sand back heavy with 2000grit should be very smooth now
Then reapeat clear with two heavy coats and sanding in between, the last coat you do not sand.
Hit with a heavy cut and polish and you will have show quailty stuff.
They will basically do the same, may look better because you arnt a pro :D
Louie did my R33 console about a year ago, still looks great and he was really cheap
Cheers
Johno
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
