when purchased 2-3 years ago my read $69 on the odo.. suuuuure it only ever did that.....
guilty until proven inocent is true. I tend to believe mine did over 100k by a bit and now is in the 130-160 mark after putting a solid 30$ on it myself.
kind of funny how all these cars read roughly 60-70k on the odo's and then after the first owner drop significant value as the first owner pushes past the 100k mark... kind of a self perpetuating cycle isnt it... fresh imports... what a crock of shit... ITS A SECOND HAND CAR FOR GOD SAKE~!
Treat it as such, think logically... hey wait... best case is that the k's arent turned back THAT far .. its just been idling in chocked multimillion people sized city traffic jams day in and day out. another option.. general cheapy that has been picked up like the monkey said and light fixer upper and sold for a mint paying all the various middle men along the way to you... orrrr its a shit box with some $$$ spent on it but mostly dodgy work....
worst case I ever saw... entire engine bay + car from snow area with salt on the roads had rust EVERYWHERE! ... resprayed straight over the top and shipped over... to bad when it got here the rust did its thing and bubbled up... the car looked like that cancer ridden chick with makeup over the mega aids xma over her face smoker add...
hmm time for a cigy... I like to tell myself it will never happen to me.
Far out I'd be majorly pee'd off if that was my car!
when i bought my 32gtr a couple months back it had done 79,000 kms im sure it may have done more but only 20,000 tops because it still had the original timing belt. one of the first things i replaced but is that a good indicator?
this is a good topic i bought mine gts skylinewith 130,000 on the clock and i believe it to be true however i have had a rb25det dropped in with supposivly 80,000k's on it? is there anyway possible to check this lol?
it would be possible to swap instrument panels. They just plug in and hey presto, low kms.
exactly, thats what i reckon they do most commonly for the digital dashs. Also if you know some one dodgy in the dealerships, they can plug in to their laptops and adjust the digitial reading, but the only problem with this is that is leaves an "imprint" on the computer saying what dealership and date something was adjusted.
My bros bosses son (bit of a tree haha), bought a a 93 r33 gtst with 65000km on the clock. I looked at it and laughed at him, biggest POS, not a chance its done less than 100000km. Even the waterpump was starting to leak coolant, and they dont go until the 150000km mark
there are dodgy people out there, but like everyone said, judge the car on its condition
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
