Ok...
I wonder what the sixth gear ratio from the 350Z is in comparison to the fifth gear from the GTT...
If it is no taller then it kinda compromises my goal of a 'cruise' gear... I mean even a gain of a coouple of hundred rpm would suffice...
Where can I find some stats on the gear ratios from both the 350Z and the GTT??
  • Replies 75
But the 6spd is going to be a close ratio box so you can run a lower final drive (ie 3.69) in the diff and still have good acceleration, yet 6th gear will be at much lower RPM on the highway even if 6th is near/same ratio as 5th in a 5spd. 9as opposed to 5spd with 4.11)
Is the Zed's final drive 3.69 is it???
So what RPM difference would I acquire with 6th gear and the Zed box compared to 5th in my GTT box?
Edited by Marco-R34GTT
HHmmmmmm, what sort of a difference would that yield??? 150/200rpm???
Wrong way matey. Zed box will make it rev higher at 110.
Looking at it, even dropping in 3.9:1 diff gears will be the only way to do it nicely (hopefully the speedo can be corrected with the speedo sender cog or something else) but even then its only about ~150rpm difference.. If you were looking for an increase in fuel economy i'd be looking somewhere else.
As an aside, I don't really mind the 4.375:1's in my car at highway speeds.
aussie zed specs.. http://www.nissan.com.au/z/specifications.asp
Edited by heller44
Changing the Diff ratio would be the easiest. Prior to owning my R34 GT I had 2 commodores a black manual & a white auto (4 speed), both had the same diff ratio (3.08:1), the black manual at 110 kph sat on 2500 rpm where as the white auto at 110 kph sat at 2000 rpm, I did some research and found that the auto top gear was 0.70:1 & the manual 5th gear is 0.81:1. Now the Skyline 5th gear is in between the commodore at 0.759:1 with a 4.111 diff ratio.
So looking at it if you can get 3.08 diff ratio it should give you say 110kph @ 2250rpm or there abouts
Hope this can help,
Phillip :D
Yeah, thats got me thinking...
Obviously with the Zed's six speed box, and the GTT final drive, of course the revs would be higher..
However, if I manage to use the Zed's box with the equivalent ratio diff....
What I'd like to find out, if anyone here drives a 350Z, is what RPM they do at 120kph... Then I'd know whether the drivetrain would be suitable or not..
convert it to a girlie box *auto*. it'll give you a nice overdrive and you could have it shift kitted so that when you wana give it some stick it'll do the job.
or wait auto's are heavier on the juice :S
I mean no malice when I say this...
But I'd rather torch my car than convert it to auto, I had an Auto N/A VL crumbledore and I will never drive another auto again....
just to help guys. the 32/33 5th gear is .83.
whereas the 34gtr 6th is .79
but the 32/33 rear diff is 4.11.1
the 34gtr rear diff is 3.45.1
hence the lower revs on the 34.
i am led to believe the reason nissan used the getrag box was to decrease the gaps between gears, hence quicker acceration as you are in the boost range more.. bernie
350z doesn't really rev that low at 100, I'll check next time Kel lets me drive it, but it feels like 6th in the z = 5th in the stagea, so its no better. I think the z box is shorter in 1-4, i never use 5th and 6th like i said the same as 5th in other cars.
anway....diff is the simplest way to lower the overall revs.
Yeah I realise that, I'm just hoping not to entirely kill the acceleration either... Shorter ratios allow for sharper acceleration whilst the taller final drive will allow me some scope to 'cruise' in top gear...
If that makes sense, sry, I'm posting after a very big aussie daayy..
Ok Folks, I asked Yo-Yo, who owns both an R34 GTT and a 350Z to take both for a spin and see what RPM's both cars achieved @ 110kph.
Here are the results for anyone who is interested...
Hi mate,
Got around to seeing the rpms for ya:
GT- T: 2,900RPM @ 110km/h (5th gear)
350 Z: 3,000RPM @ 110km/h (5th gear)
2,400RPM @ 110km/h (6th gear)
Good luck with the eventual conversion
hope that helps;
PJ
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
