  • Replies 48
A CAMS license is required, you can buy one on the day though, either a Day License or a Year License :(
$150 - Full payment for No limit car club members
$165 - Full payment + No Limit Car Club Membership payment for non members with current CAMS L2S licenses.
$190 - Full payment + No Limit Car Club Membership + CAMS L2S day license payment.
$260 - Full payment + No Limit Car Club Membership + CAMS L2S year license payment.
So is a CAMS license required or not?? Or is it just the $165??
A CAMS licence can be sorted out for you on the day. But given they are less than $100 just organise yourself a level 2S and then you wont have to worry about it for the rest of the year. Note that a prerequisite for a CAMS licence is affiliation to a club - the Nolimits mob have a club.
See here.
http://www.nolimitevents.com/e107_plugins/...viewtopic.php?2
Some things to note:
I understand you can only get one day licence per year.
A day licence is $25 (plus membership) whereas a yearly is all of about $70 more. So just get the yearly.
Edited by djr81
Well it might be worth using up that one day licence there and then, if I like it I'll get a year one...
I was under the impression that a CAMS licence required some sort of 'demonstration of competancy'... I guess I was wrong....
I don't think I'll get the yearly, I've got to get a knee op soonish, then I'll be out of my car for six weeks... After that I dunno... However I really, really want to see what the GTT has got, even though it is next to bone stock, at least I can give it some in a safe and legal environment....
Highly recommended event. Long track while the sun goes down and short track under lights. Awesome array of cars on display and some lightening times progress as the temp drops! Great event for beginners and pro's alilke.
Edited by DOGBOX
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
