Hi guys, I got 9.5" width wheels at the back for my S15, in order to pass the engineering certificate, I need to strengten the whole back end of my car with car that has standard 7.5" instead of 6.5" (on the S15) so my option is the GTR end, diff, bearing etc whatever controls the end of the rear wheels, now my question is where can I source one out? and who should I talk to get the work done?
Please don't tell me to swap the wheels to 8.5", coz I already bought the wheels and took me 1.5 months to get them :)
Thanks for the help in advance
https://www.sau.com.au/forums/topic/201638-diff-rear-end-of-gtr-for-s15/
i have a rb26/30 in my s15 and i use a complete gtr rear end, the whole thing bolts into the s15 chassis....
if you decide to use this, i think the final drive (4.11:1) will be too tall for your 6 speed as the s15 comes with 3.7:1.. this is the only thing against you... and tailshaft will be different
otherwise, the complele rear end shits all over the s15 ass end, the gtr uses a mechanical lsd, it has alloy stub axles, and thicker drive shafts...
good piece of gear compared to the s series chassis cars...
and you will never break it
Please don't tell me to swap the wheels to 8.5", coz I already bought the wheels and took me 1.5 months to get them :P
This post will be no help to you whatsoever but can I just confirm what I see here? An engineer wants you to strengthen your rear end because you have wider wheels than standard? What a f**king joke. Are you going to be driving around on Mickey Thompsons all day every day? And you can bet this guy takes himself totally seriously too.
Ok here's something semi useful. I have an R32 GTR rear end in my R34 GTT and it's a great piece of gear. Paid $700 for the whole kit and kaboodle and it's tough as nails. Really tough nails that is.
I know I know. I just hate people who blindly follow rules without question.
Think for yourself
Question authority
Throughout human history, as our species has faced the frightening,
terrorizing fact that we do not know who we are, or where we are going in
this ocean of chaos, it has been the authorities, the political, the
religious, the educational authorities who attempted to comfort us by
giving us order, rules, regulations, informing, forming in our minds their
view of reality. To think for yourself you must question authority and
learn how to put yourself in a state of vulnerable, open-mindedness;
chaotic, confused, vulnerability to inform yourself.
Think for yourself.
Question authority.
nah, only r32
ummm in my experience R34 is easier than R32.....
S13-R32 str8 swap
S15-R33/R34 st8 swap
combining the two ie R32 into s15 streches the bushes and usually ends in a skewing cradle (crabbing car) after awhile. We run R34 GTR in the S13.
and fitting the GT-r cradle wont fix your over tracked rear end..... as i assume they are worried about the track change more than anything. If you truly are being hassled for axle loading then yes it may be easier to get through with a GTR rear due to the higher factory load rating.
remmebr though you will also need new rear coil over bases as the lower mount is fork not eye.
  • 9 months later...
Hi peeps, I am in a similar situation, I have an S15 that I am currently doing an RB26DETT swap in and at the same time I am looking at swapping the GTR 32 rear end in as I got everything as a package. I want to know if I were to unbolt the entire Differential, axles, and brake setup minus the spindle from the R32 GTR rear sub-chassis would it bolt directly onto the S15 rear sub-chassis. I will be using the S15 spindle of course and using all my S15 arms and whatnot. Can someone that has done this let me know, I have the entire R32 rear end but I have already bought my S15 Cusco coilovers and don't wanna have to use a combination setup.
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
