(Ozzy)
Guys, here is the reply from SHELL. I take it that there are many cynics among you, but have a read anyway.
For what it's worth, I have given both BP Ultimate and Optimax a pretty good go each, and the only difference I can see is that I seem to get a slightly better economy with the Optimax. By the way...I do not work for SHELL.
The original claims made on this forum (somewhat a little ambiguous to me) are contained within the **
(SHELL) In reference to Optimax it will keep its Ron unless there is significant evaporation and therefore we are confident to say that it will not lose its RON rating to 94 in 3-4 days. Optimax may be in tank for at least a week at some service stations therefore we would see an increase in complaints if this was the case. Therefore it would be good for you to verify the source
of the claim as stated in the first point below.
**1. A significantly shorter shelf life. So the ron rating will decrease below 94 after only 3-4 days.**
(SHELL) Shelf life of Optimax is the same as for other types of petrol. It can be stored up to one year as long as the storage conditions are adequate, Containers used to store fuel for long periods of time should be filled to 95% full and capped tightly. Containers whould be stored out of direct sunlight and preferably kept below
27 deg C. This will help reduce the evaporation of teh petrol during storage and reduce exposure of the petrol to air and water.
**2. That optimax is a heavier fuel, so why it is a higher RON its power delivery is hampened by the cleaning agents etc in the fuel.**
(SHELL) In reference to the second point; The octane rating of Optimax is higher than the Premium ULP due to the fuel being blended from special high octane components produced by the refinery. Optimax is produced only at Shell refineries using high octane fuel components. The high Octane is due to the blended fuel and not the use of octane boosting fuel additive.
Hope this enlightens the comments made.
https://www.sau.com.au/forums/topic/20165-petrol/page/2/#findComment-440581
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
