Hi,
I've been trying to book my car in at Speedworks since the start of the new year.. No-one seems to be answering the phone. Had a friend check the shop itself last week while i was at work, and he said it was closed for Xmas till the 14th of Jan.. but yesterday and today i've had no answer on the phone again.
Thought i'd double check the phone number is 9242 8888 ?
Anyone know if they have reopened?
Their website seems to be dead aswell.
https://www.sau.com.au/forums/topic/201662-speedworks/
damn..
Any suggestions on where to get my car fixed? .. i'm in the Wembley area.
Had a problem for a few months now where the car misfires under load when it's hot. Originally around 4000rpm.. been getting worse with time / increasing weather temp.. now happens 3000 or below :)
Replaced fuel pump and spark plugs... installed a fuel pressure regulator... tried 2 sets of standard coilpacks.. tried aralditing each set of coilpacks to insulate them better...
Car is an R32 gts-t.
Mods are: pod filter, fmic, 3" catback exhaust
For some reason i'm getting 11psi boost (though i haven't been able to use it in a couple months) without any boost controlling device. .. Only other concern i have about the car is the standard oil pressure gauge reads low, but i've heard those are really unreliable.
https://www.sau.com.au/forums/topic/201662-speedworks/#findComment-3584053
it did, still traded as speedworks tho
the shop has been shut AFAIK, one of the mechanics was going to run stuff from his home garage, but don't wuote me on it as im not 100% on that..
that would be right dodgey as usual...go to tenagha motosport or kansai garage both are in wangara. hyperdrive or allstar garage in malaga, take a pick :(
https://www.sau.com.au/forums/topic/201662-speedworks/#findComment-3584825
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
