Hey People, Ive owned a R33 for about 3 years and never had a licence in this time, i get it back in around 6 months and im looking to make some decent power. My goal is around 300RWKW however im not an expert and really dont know too much.
Already have
APEXI Power FC
Turbosmart Boost T
Hybrid front mount intercooler
Turbosmart stage 3 dual port BOV
3" stainless Exhaust
Plan to buy:
Turbo HKS GT3037 Pro S (0.68 or 0.87) Internal wastegate?? i realise the 0.68 will come onto boost sooner however on a RB25 im not sure where it will top out? i think the 0.87 will me a safer bet id really appreciate the advice on this.
Nismo 740cc injectors (however looking now at 555cc or equiv nismo size) do i really need a custom fuel rail if these injectors fit?
Splitfire coils (already have coils wrapped in electrical tape)
Walbro 255L/h Intank fuel pump
I have suspension plans - strut braces/breaks (But really looking for advice on how to get to the 300KW figure).
Once the suspension, interior and such is done ill then look at doing engine and head work and possibly at that point manifold, new turbo and external wastegate setup.
Any advice is appreciated!!
https://www.sau.com.au/forums/topic/201694-r33-300kw-upgrade-plan-help/
if your going to go for the 0.68 rear i would maybe loko at the GT-RS might have better response with a 0.64 a/r rear - the compressor might be more matched/suited
550cc's nismo's are fine and direct fit for rb25 as long as you get Skyline R33 ones - ie: dont get SR20 550cc's
alot more has to be done like mani's and cams to achieve 300rwkws out of a 3037 plus 20+ psi usually however garrett gt3040 will do you better plus keep in mind if you just buy the turbo custom dump/front coming your way, oh and 0.87 safer bet on tyres n shtuff as well
hey to get 300rwkw you will need to use a 600hp+ IMO rated turbo or higher to flow that amount of air to achieve the goal even so something like a gt3040 will need 21psi+ to get this too. 740cc injectors would the min you would go in size I personally know someone though that is making over 300rwkw with a gtr-s turbo :/
The bigger the turbo, doesnt mean you have to run less boost to make the same power (neccesarily).
your still going to be running more than 16psi to make a legit 300rwkw with a 3037, probably 18+
Where a GT-RS would be 20+ to get there based on all the results in the dyno sticky thread (have you read it?)
These threads would be a good read for you
http://www.skylinesaustralia.com/forums/HK...tml&hl=3037
http://www.skylinesaustralia.com/forums/So...tml&hl=3037
http://www.skylinesaustralia.com/forums/Hk...tml&hl=3037
550cc injectors are all that's needed. Heaps of people are running them and are topping the 300 mark.
Someone mentions in one of those posts changing the head gasket to lower the compression which helped him avoid early detonation. Could be wrong on that one?
The other question you might want to ask is how long will it last without internals such as forged pistons and stuff.
My car is in at the moment getting that turbo on and should have it back in the next week or two so I'll let you know what i put down.
Ive actually found the following turbo kit!
480HP HKS GT-3037 ProS Turbo kit + Suction + Dump Pipe + fitting kit
Best for Nissan Skyline ECR33 R33 & ER34 R34 RB25det Engine
Item is Brand New. Never Sold in Retail. package included
1 x New HKS GT-3037 Pro S is 56T A/R 0.68
1 x New HKS ProS Dump Pipe
1 x New HKS Suction Intake Pipe
Full Fitting kit & accessories & Gasket & needed piping.
Full kit direct bolt on. What you see in Picture are What you get
It is sold as a full turbo conversion kit.. everything needed... ive seen a million photos... even comes with instructions :P (in japanese) lol.. its ok though.. ive swapped out turbos before.. shouldnt be to hard i hope!! the turbo on its own you can get for approx $2,822.77AU landed where the whole kit is $3367 LANDED (3 day delivery) theres also a GT2835 full kit which is also $3147.50 landed. Keep in mind.. i am eventually planning on doing engine work etc. im thinking 3037.. but 2835 seems to be a smarter more streetable idea i just really like the idea of being drivin back in the seat when it does come onto boost..
Anyone seen what a 3037 Pro S on a RB25 comes onto boost at with a 0.68 rear? a 0.87 is around 3500rpm. you would have to expect around 3000 or lower wouldnt you?
once again thanks for the advice!
IMO I'd be planning for more than just turbo + injectors + pump.
I hope you've already got a twin plate clutch and have considered some engine work (top + bottom).
If you make 300rwkw (which i hope you do) the engine/tranny will wear much faster.
You can rebuild it now for the long-term with forgies, cams, valves, v. springs etc. all to match target performance. Or you can rebuild it once its clapped out.
I wouldn't go the 0.68. You'll end up spending more money changing it over to something like a .87 the thing will hit boost and have you wheel spinning.
You will risk blowing your engine without the rebuild as many people have pointed out in numerous posts about this exact turbo and power goals.
I'll list the parts going into my car with this turbo at the moment and if maybe someone can go from there if i miss any
Exedy brass button clutch
550cc HKS injectors
Apexi PFC
HKS type s intercooler
HKS 1.6mm Head gasket
HKS cams 256 intake, 264 exhaust
Splitfire direct injection system
Tomei fuel pump
Blitz i-color boost controller
Custom exhaust manifold
4inch dump to 3 1/4 inch cat back
turbosmart external waste
z32 airflow meter
Probably a few other things to add which i forgot but others might mention.
This will still fall somewhat short of what could be achieved of that turbo. You really need to build that bottom end.
hey to get 300rwkw you will need to use a 600hp+ IMO rated turbo or higher to flow that amount of air to achieve the goal even so something like a gt3040 will need 21psi+ to get this too. 740cc injectors would the min you would go in size I personally know someone though that is making over 300rwkw with a gtr-s turbo :blink:
Go the GT-RS turbot!!!!
hey im no expert but id love to know how someone can get 300kw out of a gtrs as iv tried many times on a dyno even with race fuel 109,the turbo runs out of puff at high rpm and boost drops off but a buckets of torque ,you mite get it with nos ,thats my next step. go a hks 3037 kit with all the bits needed if you really hell bent for 300kw,a gtrs is a great street turbo it depends what you really must have.
my mods on 22 psi
Nismo thermostate
Nismo high flow fuel pump
Nismo engine mounts
Nismo gear box mounts
Nismo 550cc injectors
Nismo flywheel
Excedy custom clutch
Eagle conrods
ARP head studs
Arias pistons & rings
Acl engine bearings
Custom Radiator 40mm
splitfires coil packs
Sard sports magnetic oil filters
Sard annodised aluminium cooling oil block
Sard fuel regulator adaptor
Sard fuel regulator
Nissan N1 oil pump
Nissan water pump
Apex power FC
Greddy remote switching system
Greddy boost controller
Greddy oil catch can
Greddy blow off valve
Greddy intake plenum
Fujitsubo exhaust
Catco stainless high flow cat converter
3" dump pipe
Front mount intercooler
Custom turbo intake pipe
Custom air box
Radiator air guide
custom radiator
HKS valve springs
HKS cam shafts 256-intake
HKS cam shafts 264-exhaust
HKS turbo kit GTRS
HKS wiring harness for Z32 AFM
Bosch Z32 air flow m
Gates timing belt
Billion super solid coolant line
Edited by WARLORD
well hows this sound three guesses and then ill tell.just so i can see what one would pay to what i paid
this was done in july 2007
http://www.skylinesaustralia.com/forums/Mo...tml&hl=gtrs
Edited by WARLORD
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
