got this awesome bass setup for sale as i no longer want to focus on music (not that i really did anyways lol). have had it for a month or two but really only been used for a coupla weeks coz never had the chance to drive around to enjoy the fruits of my hard labour
the sub is rated at 750WRMS, not one of those dogsballs 1200W peak subs that you find going for $80 in your local automobile shops. the sub is in its original Kicker ported box, so you are ensured the sub is capable of reaching its potential unlike backyard jobs that are usually too large/small or incorrectly designed.
the amp is rated at 750WRMS at 1channel (its a monoblock) so its perfectly matched with the sub. you will not want to run any less power than this to the sub as it with damage it. this is one of the biggest monoblock class D amps you will find that kicker makes.
more info can be found on the kickerwebsite http://www.kicker.com/06/kicker_home.html
this combination set me back about the $1500rrp mark but now i need to let it go quick sale at $1000 the lot!! can supply a brand new kicker 4gauge 2-channel wiring kit that normally retails around $190 for an extra $120.
so for $1120ono you got yourself one BIG-MUTHA-THUMPIN setup!!
also have JVC KD-PDR35 deck http://www.ryda.com.au/JVC-KD-PDR35-Car-CD...r-p/kdpdr35.htm Kicker 200.1 amp, JL W1V2 sub in JL Audio ported box (all purchased less than a 2weeks ago) $850 firm. rrp is somewhere along the lines of 950 or so. installation can carried out in sydney at additional costs.
https://www.sau.com.au/forums/topic/201700-kicker-jvc-jl-sound-systems/
sorry guys kicker stuff is on hold- a deposit has been taken on the kicker gear
fyi its the 2ohm type
jbl sub + jvc amp still available
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
