Im considering to get a kit for my gtt r34, but im in a dilemma whether to go nismo kit or do-luck front bar, bomex side and rear???
wat do u guys think??? few of guys on sau have the kits ive mentioned if u guys don't know wat they look like...
the do-luck/bomex kit is hot, very agressive, i plan on buying that when i get the $$, sometime, in the distant future, the nismo one is nice, its more streamlined i think, more along the factory lines...
ur choice, mine would be do-luck/bomex
I would go Nismo with extra (separate) lip - Do-luck sideskirts and a put a GTR wing on.
Nice... then of course get nice 18" rims, dump it down a bit and you're set...
all looks abit to crazy for me.
I like simple, but effective. Its the way ive tried to go for all my cars.
Im keeping my standard front bar with the added lip, nismo skirts and maybe impul real. That will give me lower lines but nothing that stands out trying to be too loud :)
Here is my front bar, it may be something to consider. Not as crazy as bomex, but not at common as the nismo shark looking one.
here is the crappiest quality pic ever
and another
it may not be your style but i just thought i would throw the option out there :)
Edited by Granthem
Haha yeh that was a progress shot... wanted to see the difference it makes. here are some newer ones :D they show the front bar abit better
I do like the Do luck front, but i feel it would be too out there with my sideskirts and rear bar im planning. So i decided to keep with this route and see how it ends up. Might eventually go do luck. It creates such a big mouth on the 34!
wow the do luck is quite hot there, and bomex sides are nice as with the rear. im leaning way more on do luck with bomex kit for sho!!!!
btw granthem are ur hid bulbs 6000K ones?
Edited by 10MinuteCar
Haha yeh that was a progress shot... wanted to see the difference it makes. here are some newer ones :( they show the front bar abit better
Classy and WAY TOO HOT!!!!
Haha yeh that was a progress shot... wanted to see the difference it makes. here are some newer ones :worship: they show the front bar abit better
Hey Granthem, who makes the eyelids you have on your GTT? They fit nice.
Hey mate, they are fibreglass C West style. Unfortuntely I'm not sure where they were purchased from however, because I picked them up off the forums brand new but second hand
I do however know they can be purchased off www.carmate.com (an aus site) however I have heard mixed reviews about their quality. I can find out where they were purchased from orignially if you would like though?
Edited by Granthem
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....🤣) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
    • Swap the injectors around and see what happens. If the misfire follows the injectors then that's a signal, if it doesn't it's probably not the injectors.
    • R33 with RB26 seems to go off of learned voltage for idle. Seemed like whatever the baseline voltage was once ECU first gains power will be the idle voltage. With ignition on unplug/replugging the TPS would relearn the idle TPS voltage.
    • Have you confirmed the 2 pin coolant temp sensor on the motor is working properly? I've had a very similar issue when I forgot to plug mine back in many years ago.
    • Ok interesting i guess ill wait till using a manual gauge before making assumptions.
