Item: rb20e+t SOHC custom hight mount turbo manifold and or AUTO gearbox.
Website: this one
Item Condition: good. been in my auto Laurel since 1993 aprox 180000km on it
Reason for Selling: new motor going into my car
Price and Payment Conditions: make an offer
Extra Info: custom high mount turbo exhaust manifold (with external wastegate) and dump pipe can be bought seperatly to block if needed. The block is identical to any rb20det.. its pretty much a VL motor althought the turbo setup is custom (ENGINE WAS ORIGINALLY N/A AND WAS TURBOCHARGED) with water cooler spray jet. motor is still in my car and inspections are welcome. im keen to sell asap as i have a new motor to go in to my laurel :/ please make reasonable offers, anything above 300 for the engine + manifold + turbo and dump.. or anything over 150 for the block and the head alone. ALSO i have an AUTO gearbox that i am also willing to sell. make some offers, going cheap!! call or sms anytime!
Other parts such as loom, ecu (N/A), Altinator etc can also be bought.
Pictures: on request
Contact Details: Dave: 0411485138
https://www.sau.com.au/forums/topic/201727-rb20-for-sale/
ok so how much for turbo, wastgate and manifold and in take pipe from pod
and when dose it start to hit boost and full boost and wat turbo is it
Edited by blockasR32
https://www.sau.com.au/forums/topic/201727-rb20-for-sale/#findComment-3585112
  • 4 months later...
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
