Item: Apex'i N1 Coilover
Condition: Fair
Price: $1800
To Fit: (What car) Nissan Silvia S15
Contact: Kevin
Comments:
Hi guys,
I'm after a set of Tein Super street or Mono Flex for trade with my coilovers. They retail for well over $3500 but are not well suited to road. Excellent for track use and is a premium product. the N1 in Tein is the best you can buy, and Apex'i is no exception. These are fully adjustable spring rate, Height, Camber... the works.
PM me if ur interested.
Kevin
https://www.sau.com.au/forums/topic/201744-apexi-n1-coilver/
    • That'd be right ~ the early RE5R01A is pretty much the same as the RE4R01A in many ways ; problem is they made lots more 4-speeds than 5-speeds.... I'm in AU, so you'll need apply the US supply scene... https://www.alltranz.com.au/shop/drivetrain/automatic-transmission/Mazda/RE5R01A/#scroll-electrical_components This'll give you the aftermarket parts listings -- you're looking for #56712 & #56713
    • Haven't received that part yet, but seeing as you mentioned it I do have some aluminium foil somewhere.... it'll be good for a laugh
    • At a guess being carb all the dash loom will be different & will probably need more work there or replaced.
    • yes easily doable was very common conversion around 15+ years ago Require: Sr20 cross member and engine mounts sr20 gearbox or bell housing if manual CA already sr20 loom and ecu sr20 radiator (or make a cross over pipe to us CA style radiator) sr20 engine All parts can be sourced from an s13 Will require some mods to engine loom to body loom plugs but plenty of info out there on that.
    • Also check the factory 2 wire coolant sensor is functioning properly and plugged in. Ignore the dash, the dash uses a different temp sensor.
