  • Replies 200
In shootout mode my bitch puts out 297hp, but yesterday when it was setup properly, 331hp. I thought to myself as I was leaving Tenagah just now "Should I be good and not give my car a little squirt out of here"? That thought lasted all of 1st gear if that. BWWAAAAAAAAAAAAAAAAAAAAAAAA!
Congrats to Jonn with the 32R, Nathan's 33 for highest in class and the guy with the yellow Stag for lowest (even though it was limited by speed cut). IF 1 PERSON WITH AN RB20 TURNED UP THEY WOULD HAVE WON IN CLASS.
Yeah good day, I ran well below my target due to boost and probably some other issues. Have a long hard slog ahead of me in regards to finding and ironing out the bugs.. Hopefully one day I will make some decent power again.
i was surprised at how many lines were running lean today
will post what vids i took up over the next couple days for everyone to see
too tired now im going to bed lol (midnight start at work for me
And this is Nathan and Ryan (at least I think it was Ryan?) trying to fix Nathan's car.
EDIT: Sorry, Shayde = Carl.... I think I called you Ryan today :laugh:
And some of my engine covers :P
Edited by Topaz
what happened to the blue S15?
yeh for some reason is was running lean as. Not realy sure why though, i'll pick up a new fuel filter tomorrow and see how that goes. if it's not that i'm going to pick up fuel pump, pfc and a z32 and then we'll be talking.
im reasonably happy with my figure would have prefered it started with a 2 but thats something to work towards
what a great turnout and well run day many thanks to those who organised and well done to all for making it a great day
WELLDONE TO ALL WHO COME ALONG TODAY,THANK`S TO BRAD,& ABDUS&TENGAGAH MOTORSPORTS CREW WHO DID A GREAT JOB ON EVERYBODY`S CAR`S.HOW DISSAPPOINTING To win LOWEST HP 140.8 ???,no ture number`s to show,Will have to get speed cut sorted for next time.THANK`S TO ALL FOR GREAT DAY OUT.Cheer`s chuckie.
    • Convert to dual filament bulb   FWIW, it will look odd - I dare say a bit dumb as it looks like your flasher relay has shit the bed.
    • If the RB20 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
