Ok, not sure if this is a subject covered before but I'd thought I'd bring it up.
People talk about fitting a fuel pump to their Stagea but I haven't ever seen any detail about it.
I currently have a Walbro 255 in the tank behind the 26 but to be honest its not right. It won't run right when its cold (like its starving of fuel) & if you thrash it it doesn't seem to catch up for a while. Talking to a fuel pump expert he said that some Nissans (Z32 300ZX for example) run variable rate earths at the ECU & that may be what is causing my problem. I personally have a re-shelled 260RS if that makes any difference (including the entire 260RS wiring loom) so I'm just curious as to whether anyone has had fuel pump problems with their Stagea/260RS.
I have access to a Bosch 044 with a the appropriate fittings to adapt to the Nissan setup but have been told (by the same guy) that I will at the very least need to change my fuel pump relay for fear of burning it (or the wiring/ECU) out. Of course I haven't wanted to risk a 260RS ECU so haven't taken it any further.
I'd like to wind the boost up to 1 bar but I don't want to risk a lean out with a sketchy pump so I'm holding back at the moment but I can tell you my RH foot is getting itchy.
What are other people running in their Stagea/GTS25T/GTR etc etc?
On a similiar note; how do people wire up secondary fuel pumps? Into the same earthing point (via the ECU)?
https://www.sau.com.au/forums/topic/201830-stagea-fuel-pumps/
I think sydneykid has mentioned it before, the Walbro needs 13 + volts to perform at 255l/hr
You may only be getting 11 volts and therefore your pump is not pumping enough fuel for your thirsty rb26
Try this mod
http://www.skylinesaustralia.com/forums/Fu...l&hl=direct
Try this mod
Ahhh I see. That makes sense.
I had considered hard wiring the pump with a direct feed from the battery but my concern is of the safety side of it; I don't want it to keep pumping fuel if I ever crash it (well if someone crashes into me :blink: )
Edited by tRUkbOY
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
    • I get into huffs with people when I suggest the MX5 looks so much better as a coupe than it does as convertible. Pretty sure I don't prefer the convertible version of anything. Good job on the hardtop! The next buyer will appreciate.
    • IMO wrap does have its uses, but like you said, quality wrap, and professional installation, would probably cost want a quality paint job does, but, the paint, if maintained, is basically for life, and much easier to touch up if required  In other news: it's pissing down here, with thunder, lightning and only some small hail "at this stage", luckily all "my" cars are undercover  I've also been contacted by a guy in Newcastle about the SS, he said he will come down next weekend for a look, we'll see how that transpires I guess 🫰
