  • 3 months later...
Got it worked out. The little plastic sleeve with the 3 pins that locate in the steering wheel weren't lined up correctly
I have this problem too on the Dayz .Trouble is that the wheel I took from the 25G will not seat far enough down for the pins to engage in the holes in the wheel boss. Even driving on and doing up nut leaves the boss a good millimeter shy of engaging.
Oddly the wheel off the Dayz fits the 25G properly.
I am going to check to see if the shaft can be moved down about 3 or 4 mm so the boss can accept the pins.
I suspect the Dayz has had a front ender as it had an R32 radiator when I bought it. Maybe this is how the shaft is that few mms too far up.
Will get back soon.
What I had not noticed before is that the plastic with the three spiggots on it is actually spring loaded. Trouble was that the lubricant used was more like glue and the spring was not strong enough to push the plastic spiggot thingie out far enough so that when fitting the steering wheel back on the spiggots did not engage. Now when the nut was tightened the spring keeps pressure on so that all is AOK. I used a bit of WD40 to help the spring. Now that fixed the horn an indicator cancel
Now I have to reset the airbag controller and all will be fixed..
Edited by 66yostagea
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
