hey everyone, i recently got a new job and i have to drive pass around 3-4 speed camera twice a day.
so this is making me a bit edgey so i just want someone to help me clarify:
1, how much km do u have to go over the actual speed limit until you get snap
2, how long will it take for them to send a fine letter IF i did get caught
-pete
https://www.sau.com.au/forums/topic/201850-questions-about-fixed-speed-cameras/
1. usually over 10% of the speed limit, ie over 88 in 80 zone
2. not really sure on this but i think someone mentioned 6-8 weeks or something..
I've heard of many cases where they've been set to less than 10%.
DO NOT speed past them.......
From big-ass trips... speedos are usually set to be lower than the speed you're doing.... If you use a nav. unit, it always displays that you're travelling slower than what the speed ostates (they might not take into consideration contours however)... But the speedo-checks on highway to melbourne registered same speed as GPS; which was at least 7km/h under what the speedo read. - so don't get paranoid, but don't exceed the limit. Driving instructors recommend 3km under speed limit to do driving tests :blink:
I thought fines always come within 2 weeks?
Keep in mind that if is IS 10%, it's still not going to be a good measure, due to inaccuracies in your speedo, the camera etc. Just do the speed limit through the camera.
thats when a pfc commander comes in handy :blink:
If you know where they are why would you speed past them?
:blink:
like a few people have said, speedos in cars generally read about 5km/h over what you are doing. so if the speedo says 100 youre doing 95. so if you go through a speed camera on, or even slightly above the limit, you should be right.
cops with radar/lidar ive heard need to give a 10% leeway. add into account that your speedo is high as well..
many times ive been in a 100 zone, with the speedo reading 110 to 115, and a cop has been there, and i havnt been done.
10% are you kidding me? lol. It's more like 2 or 3km/h. so 63 in a 60 zone will most likely see you booked, as will 103 in a 100 zone. I have no idea who came up with this 10% theory, but it's bullshit.
your theory is no better
it's definiately not 2-3km/h
Too lazy to edit but:
http://www.skylinesaustralia.com/forums/in...t&p=3560020
afraid to say.. not a good year for me :)
Just curious to know, do policemen have a Flash on their Radars?? or any other speed recording device (Laser)? etc
I was doing abt 111kmh in a 100 zone :D:( silly me,
I think i saw a flash from behind some trees and an un marked commodore parked some 2km down on the M4
can't be sure if it was me, as there were a few other cars around me doing the same speed...
but then again, i can't even be sure if it was a police flash or some blue light i saw through the trees in a factory or sumthing else :D ..........
dam , sooooo anxious. hope i dont get anything in the mail.
Most radar's do not have a flash, if the radar operator sees someone doing high speeds they would radio the chasing car (in this case I assume it would be the unmarked commonwh0re parked 2km down the road) telling them that x person is speeding and to chase em down.
However there are new radar setups where the radar is on the ground and the camera is behind it. They need to have a good lock on ~3secs then takes a photo immediately. Quite easy to notice this.
I think all police officers are being currently trained to operate radars, all HWP's know how to use radar's already.
As for your case, ADR's specifies 10% tolerence for speeds, so maybe you are being paranoid.
from
http://rvcs-prodweb.dot.gov.au/files/ADR%201803.pdf
5.3. The speed indicated shall not be less than the true speed of the vehicle. At the test
speeds specified in paragraph 5.2.5. above, there shall be the following relationship
between the speed displayed (V1 ) and the true speed (V2).
0 ≤ (V1 - V2) ≤ 0.1 V2 + 4 km/h
The equation means as follows:
95 Being Indicated speed 90 being true speed.
0 <= 95 -90 <= 90*0.1 +4
0 <= 5 <= 13
So there for Indicating 95 but going 90 is in the acceptable range. Were are as
110 Being Indicated speed 90 being true speed.
0 <= 110-90 <=90*0.1+4
0 <= 20 <= 13 Which means its not acceptable.
So the allowable difference depends on the speed the car is actually traveling.
Put easier, your indicator must NOT be showing a slower speed then the car is travelling, and it must not indicate more the 10%+4km of the true speed
So In a 60 zone, your indicated speed must be between 60-70 to be ADR approved.
In a 80 zone, 80-92
In a 100 zone, 100-114
In a 110 zone, 110-125
You are wrong as far as NSW goes ( as we speak, plans are in place for much less leway) but you are correct as far as VIC goes, 63 in a 60 zone ,84 in a 80 zone and they get you. This is speed cameras only, its up to the cop if its a none camera speed trap. What gets me in the case of VIC is the fact that the equipment they use to measure speed has a plus or minus 3% accuracy according to manufactures guidelines, if I was booked for doing 63 in a 60 zone I would defend it in court and I would win everytime!!
yeah true. I still don't believe it's anything like 10% though. Someone please drive through a 110 camera at 122 and tell me what happens :P my guess is fine.
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
