well just thought, i would anounce i have a black r35 coming which should be hear in april and i cant tell ya how excited i am!!!!!
hopefully a few guys on this forum can make it out to the track when it gets hear, as we will try to get it out to QR before we start changing it.
i intend to have a section of the build process on that and the r34 timeattack car.
russ
https://www.sau.com.au/forums/topic/201859-black-r35-coming/
  • Replies 57
Ahhh, you guys built the crazy R32 GTR that recently raced at Tsukuba? Congrats on all the success :blink:
And congrats on the R35. Lots of us are dying to see how they go with mods!
Damn you have lotsa GTRs, how about spreading it around a little mate? :blink:
Nice work Russ, any particular modification plans for the R35 when it arrives?
Nick
r35 will get caged, exhaust , hopefully ecu modifier of some description for boost fuel timing & speed limiter, terratrip, seats, harness
it will be stripped out of alot of interior and not much else at this stage, want to be able to run buller and things like that.
the r34 will be 3ltr, autronic, hollinger, v8 supecar brakes, full ikeya arms, carbon doors and bonnet, caged, single seat, as light as possible for pure time attack events.
nearly all these parts are here just waiting for the bloody car!!
yeah too many gtr's! (mind you they are mark's as well!!)
my wife is really getting the shits and had enough!
but i just cant help it a lovem!! and just amazed at the new car that nissan have delivered!
Edited by giant
Before the R33 goes i so would love to see some footage of it being driven in anger :blink:
hey roy , it,s coming mate!
we stuck into it over christmas , all new fuel system , pulled the engine back out and dry sumped it, engine should go back in.
i would say it will be on the dyno in two or three weeks, want to have it finished before starting anything else,
want to do a few events in it before selling it! probably do gatton street sprints up here in march.
so i will have vids of it and pics of car sometime soon.
what would be the best optin shan?
i was going to rally rego it
well if you're gonna go balls out and race mod it then you'd probably be better off with a race import. it'll also see the car in your hands faster.
if its gonna be sedate mods then putting it on the road might be more fun/profitable when you want to sell it down the track. that said, it'll be at least 6 to 8 months before anyone can comply em.
i'd go the race import, easier, quicker and cheaper.
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
