People
i am looking at upgrade my stock turbo from my rb25det, however i would like to know what turbo could i use for quick response since i am using the car for drifting.
for boost ???
for power???
Perhaps a hybrid would me a good idea if you want quick spool-up.. :blink:
What kind of power are you running ?
https://www.sau.com.au/forums/topic/201866-urgent/#findComment-3586330
People
for boost ???
for power???
https://www.sau.com.au/forums/topic/201866-urgent/#findComment-3586334
A couple of options depending on your budget.
HKS GTRS, Garret GT 3071, Ball bearing hi flow turbo.
Probably giving you mid to high 200s but responsive.
I have the HKS GT-RS strapped to my RB25 and it's a solid responsive turbo.
Only drawback is it's price other than that it kicks arse for a stock motor application.
https://www.sau.com.au/forums/topic/201866-urgent/#findComment-3586445
  • 3 weeks later...
