People
i am looking at upgrade my stock turbo from my rb25det, however i would like to know what turbo could i use for quick response since i am using the car for drifting.
for boost ???
for power???
Perhaps a hybrid would me a good idea if you want quick spool-up.. :blink:
What kind of power are you running ?
https://www.sau.com.au/forums/topic/201866-urgent/#findComment-3586330
People
for boost ???
for power???
https://www.sau.com.au/forums/topic/201866-urgent/#findComment-3586334
A couple of options depending on your budget.
HKS GTRS, Garret GT 3071, Ball bearing hi flow turbo.
Probably giving you mid to high 200s but responsive.
I have the HKS GT-RS strapped to my RB25 and it's a solid responsive turbo.
Only drawback is it's price other than that it kicks arse for a stock motor application.
https://www.sau.com.au/forums/topic/201866-urgent/#findComment-3586445
  • 3 weeks later...
    • I would be looking at the tune mate. How do you know that you have such a low dynamic compression?  I had to dumb mine down because it was too jumpy when taking off (too much torque).  What ECU? Do you need help with the tune?
    • Surely the cam timing is set to something stupid at low RPM?
    • Hi guys, Sorry to butt in and take it slightly off course, although still on the VCAM subject.  I had VCAM put into my Tomei 2.8 bottom end and I struggle to take off because the engine has very little torque caused by VERY low dynamic compression at 60psi. But once off the mark and especially on boost, the engine rev happily all the way to 8000rpm and makes 630hp at 20psi of boost on E85 at the rear hubs. Has anyone had any similar experience or any suggestions on what might cause this low compression at low rpm? I am in the process of converting it into a 8hp transmission and with this low torque, the engine would not even stay running until the throttle is opened to more than 30% and then I loose all vacuum.
    • Last year I got a set of MCA street coilovers for my turbo Forester after my son hitting a concrete gutter/wall on a small bridge causing the whole drivers side suspension to get bent because the rain just made the car slide out I love them, I think they were $2400. even had a hiccup of have the wrong hub configuration (my fault) so got onto MCA and they sent the correct shock ends overnight parts from QLD, for free!  I was very impressed with their customer service and quality of the product
