Hey there,
just wondering if anyone can suggest things to do on a weekday night and weekday. Will be dropping by Canberra early next week to get some things done at the foreign embassy. Just a few questions which i hope some of you can answer.
1) Are the embassies far away from the city?
2) Which hotels would you recommend? Budget $150 a night.
3) Places to go after 7 for dinner ( i'll probably be arriving at that time cos of the drive from Melbourne )
4) Places to go to in the day besides the Parliament House
Thanks guys
https://www.sau.com.au/forums/topic/201873-tourist/
1) Are the embassies far away from the city? Nope, all the larger countries are just over the bridge in Yarralumla/Barton area maybe 5 minute drive
2) Which hotels would you recommend? Budget $150 a night. hmm got me there most of the good ones are more than that http://www.wotif.com/search/Advanced?selec...urrencyCode=AUD
3) Places to go after 7 for dinner ( i'll probably be arriving at that time cos of the drive from Melbourne ) - Depends on what you like I personally always go to Ginseng in Manuka it is the best Chinese in Aus well I haven’t been to flower drum but it's meant to be almost as good as that.
4) Places to go to in the day besides the Parliament House - War Memorial, National Museum etc check out http://www.visitcanberra.com.au/
https://www.sau.com.au/forums/topic/201873-tourist/#findComment-3586466
the Olims Hotel is probably a good choice. its located right in the middle of where most of the embassies are and rooms are ~$140 per night. http://www.accorhotels.com.au/5509
Thanks buddy, i'll have a look at that. :/
BTW, do you guys have a monthly skylines meet as well? Wouldn't mind dropping by to check out the cars :huh:
https://www.sau.com.au/forums/topic/201873-tourist/#findComment-3588989
he said he wont be here till next week, Mick :)
You'll find plenty of places to eat in Manuka or the City. I'd personally eat at Manuka at stay at somewhere like Rydges Capital Hill which is just down the road. Both are very close to the embassies in Yarralumla.
TiTAN, Olims is in Braddon! Wrong side of the lake! lol ;)
https://www.sau.com.au/forums/topic/201873-tourist/#findComment-3589210
What time does shops normally close on a Tuesday night?
which shops?
shopping malls and stuff would close at 5.30pm, but Woolies and Coles are open till about midnight... actually the Coles at Manuka is 24hours (the only one in Canberra).
there's plenty of 24hour servos too.
https://www.sau.com.au/forums/topic/201873-tourist/#findComment-3589863
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
