Looks good mate, who built it? and what specs?
Just a thought, while the motor is out, to put an oil return from the back of the head to the sump.. will help a lot with oil control.
Cheers
Johno
due to the size of the sump its not required, also the oil return galleries have been enlarged. This mod (external return) is mainly needed when larger volume pumps are used with STD size sumps i.e. to stop them being emptied at high revs.
colour is candy apple red...although it looks orange in pics...much deeper and darker in real life.
https://www.sau.com.au/forums/topic/201880-rb26/#findComment-3586840
Its got everything i think
Mahle Pistons
Tomei cams 280 10.5mm lift
Eagle rods
Hypertune Plenum
N1 block
Nitto valves
Tomei buckets & springs
Head work
R33 crank Grubbed screwed
Greddy oil pump
700cc Injectors
Greddy fuel rail
HKS T04Z
Trust manifold & Wastegaste
Should make some good numbers i hope any1 wanna make a estimate on power going 2 run 30psi or 32 pound if turbo can handle on race fuel once run in
https://www.sau.com.au/forums/topic/201880-rb26/#findComment-3586866
700-750 on 30psi
700 is over 500KW...750 is 550KW....you are kidding right...probably make around 450KW. But Dave is using the best tuner in Aust. for the numbers so it might go higher. At least it will have a good spread of power and most importantly torque.
and im sure it will chirp 2nd!
https://www.sau.com.au/forums/topic/201880-rb26/#findComment-3587387
    • I didn't know about induction heaters but checked them out and they look awesome but too pricey for the occasional job like this. And I'm too nervous to take a flame anywhere near there as the petrol tank is so close, although I was intrigued with the crayons suggestion 馃榿 I filled a coke bottle lid with penetrating fluid and raised it on the jack so the nut was submerged in it all night. Then went in with a tiny cold chisel and got it almost to the point of splitting but not quite (I didn't want to damage the bolt threads). Then I hammered a socket back on and gently worked it until I felt movement. And it's off 馃榾
    • I should. But it already uses too much fuel for a daily. You might note my recco for engine chnages are almost exclusively to people who have it as a weekender/summer car. I don't even have room to keep the spares for this one, let alone another car.
    • If I had "perfect R33 GTR" kinda money I would have bought one of the crazy expensive low mileage HJA cars, but I am sadly not that wealthy. I already picked this car out of various Skylines for sale locally, most of which were worse in some way. Only a few cars were actually better but also more expensive. In terms of buying a motor locally, I at least have the option to inspect it myself and juding the seller as a person, and used or freshly rebuilt engines that some people sell are actually ok price-wise. I knew the car was going to require work, but shit piled up real fast and I haven't even driven 1000km yet as the turbo started oiling like a bitch within a few weeks after I got the car.   I assume it wasn't actually me who cracked it, though there is no way to know when that crack formed and if the previous owner even knew it was there. Buying another 05U Block can be a gamble, yeah, but the cheapest PRP cast block is like twice or more money-wise, and billet is 3 or 3 times as much. For now I am most likely just keeping the current engine, as a rebuild or engine swap isn't happening right now. But I am seriously considering buying a second engine and selling mine in return. Might be a sweet deal at the end.
    • Hi all. I need some help buying the correct size banjo bolts for my 2860 turbos. Because whoever installed them tore up the original part, I ordered new ones of this kind, because I just figured these were the most leak-resistant option as I already had trouble with a shitty braided line. I need to know the thread size of the smaller left hole, that is the turbo oil feed connection. I found out so far that the turbo oil inlet apparently has a 7/16"-24 thread, but I cannot find any listing or description of the thread size on this line. I do not have the original bolts. I tried using the bolts that were in the turbos (the ones that were mounted with the shitty braided line) but they sit very loosely so they can't be the right thread. Means either these bolts are the wrong ones (how do they fit the turbo then? no clue) or the wraparound-lines have a different thread than the turbo oil feed itself. Help is appreciated, asking Nissan directly is obviously not going to work.
