Interesting perspective. Did you have any suspension mods done to your SS? Only because mine was lowered and had aftermarket springs & shocks and it felt fantastic around corners. It suprised a lot of people. Never drove one with standard suspension though so I can't really comment.
I'd probably agree with him, I had an LS1 V8 VX for a little while and it had a slight drop and 18rims and it was horrible on corners, the slightly older version V6 (Supercharged) roughly the same time I was driving on and off running on regular suspension was a much easier car to live with in terms of balance and handling.
Neither I would consider 'remarkable' in terms of power for what they where and how they managed to put it down which was clumsier than a teenager grabbing their first boob. The V8 does have good amounts torque and it doesn't take an awful lot to get a lot more power out of the engine with some very cheap mods. Aside from that I find it very hard to praise much else about them apart from the price (which is quite low) and the list of things which sucked was very long...
i have driven vx ls1 5.7l and vz ls2 6.0l ss and a ba ford xr8. the commo's feel more sporty. where as the fords felt more like a family car. try them out. both are spacious and both have great straight line grunt. and will tow ur family with a car load of stuff with a trailer on the rear.
i used to own a vy ss 5.7 litre. go very well. also driven a vx ss and vt ss (all gen 3's). not much difference between the vx and vt ss
but id definitely buy a vx ss if youre saying you have 15k to spend. 16k and youll get one. obviously petrol
is a killer avg 17l-18l per 100kms. i love holden v8s (although i have an s15). i say buy it its worth it for what you pay.
And I thought my skyline was thirsty at at just over 12 litres per 100 km...
  • 1 month later...
When i smashed my car i was looking around for an Aristo.I would get one of those over a SS.All the luxury stuff,good on fuel when you just want to potter around.And with a few mods will smash a SS anyday of the week.
That's the way I've gone - an Aristo - cost all up under 13 registered - imported through an agent - looked at 40 before finding a good one though! Haven't been able to drive it yet as we're still waiting for compliance plates and have been waiting since jan. A pain in the butt as there has been a big influx of Aristo's... that's what the compliancers are saying anyway.
Cheers
mark,
id say 200 rwkw and up.
200 can see skylines in the 13's and well set up, low 13's
about the same as a bolt on modded ls1 (say vt - vx) and now these days you'll need more as even cammed LS1s are getting around the 250 - 300rwkw (SAU NSW Dyno day just gone, Josh got 301.?rwkw in his cammed and tuned VX SS)
when he had 230rwkw he did a 13.1 @108 - 110?
mark power to weight is key here....
roughly... a conformodore ss weighs 1.65 ton and a 33 gtst (staying 2wd here peeps) weighs 1.39 ton
for a power to weight ratio of roughly 100rwkw per tonne a
skyline needs 139 rwkw
conformodore needs 165 rwkw
meaning that a gtst needs roughly 18.5% less power than a commonwhore at stock weight to be the same kw/tonne
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
