Item:HKS intake and exhaust cam shafts 8.8mm lift 256 duration
Age: 2 hours used, made a couple passes on the dyno basically NEW!
Condition: Basically NEW
Price: $425.00 US + shipping to the AU or USA
To Fit: (What car) Skyline r33 rb25det late model s2 engine with BLACK CAS or any s1-s2 with black cas.
Contact: email: [email protected]
Comments: I'm a verified Paypal member any questions of offers please feel free to contact me. Item will be insured for shipping, and once purchased will be shipped ASAP.
Pictures?
Heres a picture of the exhaust shaft, I can get one of the intake as well if needed or then side by side. Excuse the assembly lube on the shaft, it shows you how new it was since it hadn't even came off yet after installation and removal.
I checked some shipping costs as well, looks around $85-90 US for shipping for both cams to the AU.
Heres pics with them together. I took a close up of the lobes and journals to show there perfectly new. Once again there is still assembly lube on them. I'm keeping them oiled so they don't rust.
still for sale!
Hey dude!
I'd love to buy these shafts bad! If they are still up for sale at the end of march i'll buy. I have spent nearly 5k lately and have to chill for a bit. If I don't my missus is gonna leave me. lol.
Bitches just don't get it! Then again there's a kid involved so I gotta play it right.
Hey dude!
We'll let me know.
Still for sale.
  • 3 weeks later...
  • 3 weeks later...
  • 4 weeks later...
OK, both shafts still for sale. I'm going to take a huge hit here in resale....
We are looking at now... $500AU SHIPPED OBO.
email: [email protected] I need these shafts gone ASAP.
  • 1 month later...
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
    • I remembered wrong, but was close though 1Kz setting because those Jaycar SSRs don't go any faster, 1x pump per SSR with flyback diodes & heatsinks. In saying that, the heatsinks are overkill. Just on an alloy plate is more than sufficient. You'll find without a flyback diode, your SSRs will heat up big time and also die prematurely.  I've been running the two same SSRs since the last motor, no issues, car does 2 hour straight drives in summer once in a while and gets punished on the track. Nothing melts, no hot messes, etc.
    • Hmm. You're probably best off working out what the lobe centreline or even the LSA is for the stock cams, with VCT OFF. That's bound to be out there somewhere. Then, work on the assumption that the Kelford centreline is probably the same, and wouldn't be more than a couple of degrees away, if it is different at all. I'm very surprised that you needed to adjust the exhaust cam by 5° to get it on spec. That screams there's another problem somewhere. Anything from the belt being 1 tooth off (how many degrees is one tooth worth?) to simple user/measurement error on the degree wheel. I say this because Kelford, like most quality cam manufacturers these days, does a pretty good job of actually making the cams to spec, not relying on patching it up afterwards like we had to do back in the 80s.
    • Besides packing it, you can also fill your pump through the oil filter inlet port. After cranking for what felt like an eternity without pressure, i fed a tube in through there and filled it with oil. Cranked for a few seconds after that and had pressure.
