The tuner that tuned my PowerFC has said "we don't want you seeing how we tune", and the only way to unlock it is if they reset all the settings :D
Soooo is there somebody nice enough to spend 3mins to untick a handful of checkboxes on their datalogit gear pleeeeeeease? :)
EDIT: I'm willing to travel to whereever help is :D
Edited by _Wing_
https://www.sau.com.au/forums/topic/201912-fc-datalogit/
where are you? and are you sure it can be unlocked without a password?
I know some tuners have strong feelings about this, but to me if I pay, I buy the intellectual property as well as the results of the tune. Unless they are way cheaper than other shops which I bet they were not......
https://www.sau.com.au/forums/topic/201912-fc-datalogit/#findComment-3587157
I think its BS that a tuner would not let you look at the settings. After all, you _paid_ for this tune.
Unforunately the PowerFC can only be unlocked with Power Excel or FC-Datalogit. No PIN # or anything.
Edited by Busky2k
https://www.sau.com.au/forums/topic/201912-fc-datalogit/#findComment-3587856
i have it mate. I am in newcastle and i can unlock it for you anytime this weekend.
If your keen for the drive up i can save the tune to a USB key for you as well so you can look at it in the software.
anyway PM me if your keen, only just got the software yesterday so yeah im keen to help out.
PM me for my phone number
https://www.sau.com.au/forums/topic/201912-fc-datalogit/#findComment-3588943
    • Hey all,   I’ve got an RB25 with a trigger kit that includes a crank wheel, and I’ve hit a wall trying to sort a timing belt tracking issue. The belt either rides right on the edge of the cam/crank pulleys or walks slightly forward once the engine starts. It tracks okay-ish for a moment, then creeps right to the edge—and honestly, it’s stressing me out.   I’ve spent hours removing and reinstalling the belt, double-checking everything:   Tensioner setup is good, checked multiple times Idler pulley and washers are all in the correct places Followed the RB25 timing procedure step-by-step     The only thing I changed was the rear crank washer—I swapped the OEM one for a Neato version, and it made things worse. The belt now sits even more forward than before. I’m beginning to think the crank trigger wheel itself (from the trigger kit) is the issue—poor design or slightly off dimensions.   What’s strange is that with the previous belt setup, it actually ran fine for a couple of years—around 4,000 to 5,000 miles, even with hard driving and high RPMs. But even then, the belt was always riding right on the edge, and I know that’s not ideal or safe long term.   At this point, I’m debating whether to:   Machine a few mm off the crank trigger wheel to bring it back in line, or Replace it entirely with a better-designed unit     Only thing is, I already have the Cherry Hall sensors, bracket, etc.—I just want to replace the wheel only, not the entire kit. Anyone know a brand or supplier that sells just the crank trigger wheel on its own?   Would really appreciate any feedback—especially from anyone who’s run into this exact issue and found a reliable fix.   Thanks in advance.
    • Hi...a little refresh. Is Nistune gonna be enough to run BoV? Or do i need some proper ECU?
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
    • Such a shame places like Amaroo Park have been redeveloped, smaller tracks always make for good racing. Cheers for sharing @PranK there's some good Lakeside video's too. Its so hard with older the cars as parts are so rare and everything was made for a particular chassis at that point in time. Even the V8 Supercar Blueprint era cars are all different between each chassis within a team as they learnt things and made improvements. The COTF cars between each Chassis builder is different too especially motor/oil systems/intakes. The Group A stuff is worth so much too especially chassis with good history. The only way to do it would be composite panels and similar engine drivelines to the original cars. Ford sierra running Focus RS driveline, Commodore running a short stroke LS/LT or a Falcon with coyote and a H Pattern dog box. Could use a standard ecu across all models with a Torque Map and DBW for parity which is not even used in Supercars currently. Hell a TCM is almost a full chassis car these days and the suspension is not even close to standard style in the front running cars.
