marmo Posted January 17, 2008 Share Posted January 17, 2008 hey guys i bought a twin plate clutch recently 2nd hand, I put it in yesterday, and it was all good, but i wasnt sure if i had the right hight bearing carrier in it. So i removed the engine and transmission again this morning, pull it apart, and belive i had the right hight for the bearing carrier and bearing(if some one could please post the rights specs for the carrier high with the bearing on it . I began to put the gear box back onto the engine, and the splines jamed and broke the main clutch disc. belive its a Nismo Gmax one, however there isnt really any part numbers except for on the pressure plate. they are as follows 6G24 and opersate it on another one of the pressure plate toungs 9238200502 here are some pics below of the damege i did and what the clutch looks like any help where to get these clutch discs from and how much would be great ps with the carrier picture i attached i put an imitation bearing on to show the messure ments(only ruff, i did them with a tape mesure, and in a rush). so is that the correct one for my twin plate? Thanks for all your help Link to comment https://www.sau.com.au/forums/topic/201931-nismo-gmax-twin-plate-clutch-discs-replacment-bearing-carrierbearing-info/ Share on other sites More sharing options...
marmo Posted January 17, 2008 Author Share Posted January 17, 2008 Any help would be greatly appricated Link to comment https://www.sau.com.au/forums/topic/201931-nismo-gmax-twin-plate-clutch-discs-replacment-bearing-carrierbearing-info/#findComment-3587804 Share on other sites More sharing options...
stasis Posted January 20, 2008 Share Posted January 20, 2008 you might want to call the NPC clutch place in queensland. they might be able to help you ith it. Link to comment https://www.sau.com.au/forums/topic/201931-nismo-gmax-twin-plate-clutch-discs-replacment-bearing-carrierbearing-info/#findComment-3592246 Share on other sites More sharing options...
STATUS Posted January 20, 2008 Share Posted January 20, 2008 i have the same clutch sitting in the garage, part are avail but depending on what you bought the clutch for will cost you that price again. EXEDY australia can supply new discs but they prefer you to show them to them. where are you located? Link to comment https://www.sau.com.au/forums/topic/201931-nismo-gmax-twin-plate-clutch-discs-replacment-bearing-carrierbearing-info/#findComment-3593086 Share on other sites More sharing options...
marmo Posted January 11, 2009 Author Share Posted January 11, 2009 Im from Seaford, just next to frankston. Link to comment https://www.sau.com.au/forums/topic/201931-nismo-gmax-twin-plate-clutch-discs-replacment-bearing-carrierbearing-info/#findComment-4361598 Share on other sites More sharing options...
T04GTR Posted January 16, 2009 Share Posted January 16, 2009 cool. you need to use a small throwout bearing on a 12-14mm carrier. same as os giken. ottomotto have them in stock. the standard bearing and carrier is wrong. i got quoted $700 a plate from sbc.... a few years ago. i still have it rusting away in the shed as its just not worth fixing. Link to comment https://www.sau.com.au/forums/topic/201931-nismo-gmax-twin-plate-clutch-discs-replacment-bearing-carrierbearing-info/#findComment-4372986 Share on other sites More sharing options...
T04GTR Posted January 16, 2009 Share Posted January 16, 2009 the bearing carrier height is measured from the surface of the bearing seat(bottom of where the bearing sits) and where the fork rubs on the 2 tangs. Link to comment https://www.sau.com.au/forums/topic/201931-nismo-gmax-twin-plate-clutch-discs-replacment-bearing-carrierbearing-info/#findComment-4372990 Share on other sites More sharing options...
GTR1993 Posted January 25, 2009 Share Posted January 25, 2009 the bearing carrier height is measured from the surface of the bearing seat(bottom of where the bearing sits) and where the fork rubs on the 2 tangs. Hey would this be the same for a blitz (i think they made by ORC) twin plate, im having difficulty finding info about it. Link to comment https://www.sau.com.au/forums/topic/201931-nismo-gmax-twin-plate-clutch-discs-replacment-bearing-carrierbearing-info/#findComment-4388623 Share on other sites More sharing options...
S13_DriftR Posted February 1, 2009 Share Posted February 1, 2009 The correct Carrier length should be 12mm as far as I remember... The Bearing & Carrier can be bought Genuine from Nissan. With the Clutch Discs, Are they 215mm?? These can be purchased through Xtreme Clutches in Adelaide or even JMS (Japanese Motorsport) also in SA. They are normally around $600 or thereabouts... Otomoto (Ben Ellis) is an OS Giken Distributor so he may also be able to help you too. Link to comment https://www.sau.com.au/forums/topic/201931-nismo-gmax-twin-plate-clutch-discs-replacment-bearing-carrierbearing-info/#findComment-4401494 Share on other sites More sharing options...
