where is our spot anyway :D
Has a map been made up yet?
This will probably be the last showing of the skyline for me, after this the cars getting a major service (clutch, belts, fluids, brakes, normal 100,000km stuff etc) and then its up for sale :/
Edited by Baconer
  • Replies 114
Posted Images
No mention of SAU ACT though, so can't see where we might be.
Wheels_Map_2008_1_.pdf
I imagine we'd be in that big "See Attachment" area where is says "Skylines" near Reconciliation Place.
SDMA will be there too, might put the FH in that group - Are you going to take the BMW Jeno?
Had me a bit worried there lol. I couldn't find it either. Did put us in for 25 cars, although I don't think we'll reach that number. looks like similar spot to last year. Good to have the tent, otherwise we'd be BBQ'd ourselves.
haha i remember sitting in the shade of peoples cars to escape the heat, dam expensive water on a hot day and dam tempting BBQ.
Thats the exact same position as last year but we are parked next to the celicas this year, if only i could bring both cars down :thumbsup:
So is anyone else heading down earlier to put the tent up?
Ok, Lets say we'll meet at the museum at 8am - leave at 8:30am to arrive at the display area around 8:40am?? Sound ok? Anyone who turns up late can just rock up to reconciliation place when they can. My mobiles currently on the blink. But trying to fix it.
Any late drop outs or entries?
im hoping to make it...is it too late to put my name down?
Not too late, its more a record of who's turning up for our sake, I did put us down for 25 cars, but I don't think we'll get that much, it's pretty casual a show, if people need to leave early on in the day that's fine too. Just if people are going can you please copy the list from the front and then add your name, any other people who want to come just copy the list from the previous poster.
I have the little skyline writeup book somewhere, will see if I can print it up before hand and stick it up on some cardboard or something to display on the day, to show a bit of the differences between the generations. Or if someone has a display board I can put it on that'd be great, I think its about 6-8 A4 pages long.
Just to confirm who is bringing the banner?
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
