Make: Nissan
Model: HR31 Skyline GTS
Milage: 185 *** km's
Transmission: manual
Colour: white
Currently registered? Yes, until ocotober 08
Price: $6500 firm
Contact: Jon 0409 116 569 [email protected]
Comments / Modifications:
Silvertop 20DET (80 000km's)
RB25 Turbo
3" Custom Exhaust
FMIC custom piping
BOV
SAFC2
RB25 Clutch, Very good condition
R32 RB20DET Gearbox
Bosch 910 External Fuel Pump, good for atleast 350rwhp
Surge Tank, mounted under the car and painted black, no fuel smell
Aftermarket Suspension, KYB shocks, lowered and stiffened springs
Selby sway bars F+R
Noltec Solid Rear Subframe Bushes
GTSX Brakes, also got Some stagea/R33 rotors sitting here which will go with the car
15" x 6.5" BBS Mesh Rims
215/60/15 Grid IIs front, near new 95% tread
195/60/15 Kendas rear, 50%
Comes with 2 spare stocker rims off some other nissan, 15 x 6 with 205/55/15 Grid IIs
Turbotech Ball Bearing type boost controller
JVC MP3 deck, 6" speakers all round
Apexi Power Intake Pod with neat heat shield and CAI
Boost Gauge
Only selling because i want to buy my brothers car which he needs gone for the money. Featured in HPI mid last year when steve may had it, different motor etc now. Was tuned by Hyperdrive and made 248.4rwhp. Spent Over $1700 on it since i got it 5 months ago. Serviced every 5000km's, always run on premium. Just changed Diff oil with good Quality Limslip LSD oil. New rear wheel studs. Everything is in good condition and works. Interior is in very good condition. Body is in good condition. Air con has been converted to the new gas setup, just needs gas in it.
Images:
Edited by JonnoHR31
https://www.sau.com.au/forums/topic/201995-wa-hr31-4-door-6500-price-drop/
  • 3 weeks later...
  • 3 weeks later...
brand new kyb front shocks purchased
brand new rear coilovers (kyb shock, spring, top hat etc) purchased and fitted
deposit taken
just paid 6 months rego
  • 3 weeks later...
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
