hey
my 32 gtr has tein coilovers in it
but they are so stiff that driving on the road you feel like the car shakes if you go over a bottle cap :huh:
so was wondering if to soften them i turn the damper adjuster clockwise or anti clockwise
and also how do i get to the ones in the rear ???
thanks in advance
https://www.sau.com.au/forums/topic/202033-tein-suspension/
  • Replies 43
If its really stiff you probably have the imported "Jap" TEIN's or the more track focused ones, the super streets are quite comfortable.
Your problem wont go away by adjusting the shocks, Im pretty sure it will be stiff because the spring rates are really heavy.
https://www.sau.com.au/forums/topic/202033-tein-suspension/#findComment-3589779
i believe swapping springs wont to much for you...maybe damage the shocks more because they are valved to a particular spring rate. i think the money spent on new springs and fitment, you could buy sk's setup or something else thats built for the streets and recoupe some of the costs in selling the teins.
https://www.sau.com.au/forums/topic/202033-tein-suspension/#findComment-3589799
anyone have any options for me
I have Type Flex on my 34 and they are firm without being overly so. I had Fulcrum change the springs for to a softer set and made a huge difference. Original ones made the car like a go kart to drive. They shifted rear spings (softer than front) to front and put a softer set on the rear to maintain the balance front to rear. Only other thing to do is to have them re-valved to allow a higher by-pass rate. You can generally get by with a 1-2 kg +/- in adjustments.
cheers
Muz
Edited by Muz
https://www.sau.com.au/forums/topic/202033-tein-suspension/#findComment-3590045
yeah i though similar, cos with the softer spring you could probs bottom out the shock if it was low
either way im thinking i may sell these and get a different suspension set up
anyone know whats got a good ride but can still look tough, if its not a stupid question
https://www.sau.com.au/forums/topic/202033-tein-suspension/#findComment-3590149
Over 150 Skylines with the Group Buy kits dissagree with you.
Cheers
Gary
Is that because they don't know any better??
I find it really hard to believe that all these '150 skylines' have tried the Aus spec super streets and changed to the Bilsteins because they were better...
https://www.sau.com.au/forums/topic/202033-tein-suspension/#findComment-3595019
I certainly know better and I have tried many sets of Teins in many cars. In fact one of our team race cars (not a Skyline) has a set of N1 Teins in it for the Bathurst 12 Hour. In some cars they work, and in others they don't. I have changed 8 Nissans so far (not all Skylines) over from Teins to Bilsteins and all of them have recorded faster laps times. For example a 225 rwkw200SX road car, Wakefield Park, 1.06 using Bilsteins down from 1.09 using Teins. At the same time they have better ride comfort and don't require intimate knowledge of damper adjustment effects.
Anytime you want to try a back to back test let me know.
Cheers
Gary
https://www.sau.com.au/forums/topic/202033-tein-suspension/#findComment-3595493
Cheers
Gary
Wakefield used to be very bumpy apparently, so I'm not surprised a softer setup might have worked better there. But where they group buy spec Billies? The ones I've seen ont he track look awful soft! Who knows, he might have made the same, or better improvement going to Aus spec Teins, or even Jap spec Super Streets. There's alot of different Teins out there, to just lump them all in one basket as crap is wrong.
for example an R34 with off the shelf Aus spec teins with no development time finished 10th or 11th outright in Targa Tasmania. Not a place where poor quality shocks, or stuff that's too stiff, are ever going to work.
I've got Jap spec super streets in my current road car (not a Skyline) and comfortably drove 1180km to Wakefield Park last weekend and got 5th outright in the wet afternoon session on that track I've never been to before, with only AWD cars in front of me, and plenty behind me too. (I was in a rwd turbo car, standard apart from Teins and exhaust)
Point is there's all sorts of Teins, and some of them work very well. From my experience with Tein Super Streets, and knowing the bloke who developed the Aus spec Teins up here in Brisbane, I woldn't hesitate to recommend Aus Spec Teins.
https://www.sau.com.au/forums/topic/202033-tein-suspension/#findComment-3595738
Same result at Philip Island., 1.5 seconds faster there
Yes, with my normal valving specs, they did have my usual coil over conversion with Eibach coils
They shouldn't be using shocks to control roll anyway, that's the swaybar's job.
They had been back to Fulcrums 6 times for improvement, with 8 spring rates tried.
Obviously Harry, you and I can tell the difference and have enough knowledge and experience to determine what works and what doesn't. We know which way to adjust them to achieve the desired result etc etc. But how many people of SAU have that sort of experience and knowledge? They would be much better off with a package that is a simple bolt on, knowing that it can do the job, day in day out circuit, drag or road.
I bet 7 or 8 of the cars in front of it had Bilsteins or Boge (Sachs), from memory
2 x STis, they come standard with Bilsteins
5 x Porsches of various models, 2 I know of with Bilsteins and 1 with quad adjustable Sach, the rest with Cup style Sach.
Rick ran his usual preference of Proflex, which he is also using at the 24 Hours of Spa
I don't know what shocks the Lambo had in it, Koni I think
Stokel changed the Mini from Sach (2006) to Ohlins (2007) from memory
That about covers the Top 10.
Maybe he would have finished higher up with a better choice, who knows.
But Harry, you can drive, which as we all know is a big factor in the wet. Plus the super streets in your car are not the same as the super streets in Skylines, so any comparison is meaningless.
We get good results from the Teins we use as well, but not in Skylines. Keeping in mind that the ones we use cost about 5 times what Super Streets do, as we both know sophistication in shock valving costs, you get what you pay for.
Cheers
Gary
https://www.sau.com.au/forums/topic/202033-tein-suspension/#findComment-3595877
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
