has it just started doing it?
have you done any mods recently to cause it? i.e. spark plugs, exhaust, timing, etc?
it's not exactly normal, but also not surprising.
the fuel mixture does normally run rich in the high rpm range.
https://www.sau.com.au/forums/topic/202039-car-back-firing/#findComment-3588962
mine does it aswell, nearly all the time in 3rd.
its just because the fuel runs rich then when you put your clutch in all the unburnt fuel thats left sitting around pops.
its not a bad thing.. i personally like it as mine sometimes makes a tiney flame :(
when i get my safc2 and get the air/fuel mixture tuned it will stop this..
https://www.sau.com.au/forums/topic/202039-car-back-firing/#findComment-3590386
check the forced induction section man there was a technical write up about it..
basically your car is running rich.. when the fuel comes into contact with oxygen it creates a popping noise.
thats about all i can remember. but it is in the FORCED INDUCTION section.
https://www.sau.com.au/forums/topic/202039-car-back-firing/#findComment-3592569
thats called overrun
thats different to backfiring cause the engine is at high-ish revs, but there is no real load on the engine, and so it revs without using the accelerator
there is an excess of fuel in the burnt mixture because of the closed throttle, and when it hit the cat converter it mixes with a bit of oxygen and self ignites
thus the pop/gurgle/burping noise
backfiring is like a full on ignition of fuel/air mixture partially in the engine and in the exhaust - thats why its loud and bad for your engine
https://www.sau.com.au/forums/topic/202039-car-back-firing/#findComment-3592934
I love my NA,
Going threw shopping centres as your slowing down, makes all the burping and dull popping noises.
Every one looks :(
grrrr lol while I sit at home on Fridays when I don't feel like spending cash going out bored out of my mind hahaha
edit: Yea the only part of the exhaust that was still stock was the cat. So in the future if you ever wanted to upgrade something I'd look at getting a high-flow cat maybe, but yea it sounded and went nice anyway =P
Also have you done anything new to it?
https://www.sau.com.au/forums/topic/202039-car-back-firing/#findComment-3597699
Just a few little things here and there.
Changed the gear knob pretty much straight away, has a gt nismo titanium on there now, lining up a new clutch soon, and also suspension. but besides that, shes still the same from the day i drove away.
Hows your legs going for transport?
https://www.sau.com.au/forums/topic/202039-car-back-firing/#findComment-3599594
Ahhh they go ok, thinking of lowering them a little and putting some 18's on there :laughing-smiley-014:
https://www.sau.com.au/forums/topic/202039-car-back-firing/#findComment-3600946
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
