If its popping on decelleration or gear changes, whats the cause of that? the BOV?
see what i wrote:
thats called overrun
thats different to backfiring cause the engine is at high-ish revs, but there is no real load on the engine, and so it revs without using the accelerator
there is an excess of fuel in the burnt mixture because of the closed throttle, and when it hit the cat converter it mixes with a bit of oxygen and self ignites
thus the pop/gurgle/burping noise
backfiring is like a full on ignition of fuel/air mixture partially in the engine and in the exhaust - thats why its loud and bad for your engine
so the so called overrun ain't bad for ur engine? cuz i have that exact described issue "overrun" like QUITE OFTEN during driving which i really think the BOV is the cause for cuz other than that i have just a catback exhaust (with stock cat convertor) and it overruns very often. One more thing, it occurs at low RPM like around 2-3k rpm ... stilll is overrun?
BTW: sorry to borrow the n/a thread like dis as wat i said about BOV has nothing to do with the thread starters issue obviously
Edited by R33Turbo
hmm, maybe your issue is more over fueling and not burning all of the fuel properly
i would look at maybe getting the Oxygen sensor changed, getting the timing checked, really, just checking out the fuel delivery system to make sure it is all good and that all sensors are working properly..
absolutely right r33turbo. vta bov's do make the car backfire...purely because thats what they do. when i switch back to plumb back....all my pops are solved...but not as aggressive to drive.
my vta bov has a larger diameter valve. hence more air can get out. with it on, i chirp 3rd.
its gives better response imo
stock bov does shit all. probably leaks etc
Edited by r33cruiser
  • 3 weeks later...
Yeh mine back fires sometimes also, i got a new exhuast system put on in december last year, and beginging of feb the hi-flow cat was stuffed, it rattled and made my exhuast sound like sh*t, the guy asked me was my car back fireing i said sometimes, he replaced it under warranty no worries, but was prob cause car was back fireing maybe, to what u guys have been saying, just hope it doesnt stuff up again. What would i have to do to fix the issue.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
    • Can you covert an R32's AC from r12 to r134 if the compressor/hoses etc are still all good? Pretty sure on my car the AC was degassed when it was imported  to remove the naughty r12 and save the ozone layer, and the fancy climate control system just blew air around. Was happy to drive the car with windows down back then, but now I am old and need to be kept cool
    • Just to circle back here, I've sold my automatic trans to another Stagea owner in OH.
