Hey guys,
looking to 2 new rear tyres today as I have mysteriously worn my oldies down past the wear bars & pretty much into ultra slickness (can't quite put my finger on how tho lol). Neways I have stockies on @tha moment 205 55 R16 & was just wondering wat the max width is that I can go? Yes i want to keep the 16s cant afford rims yet :huh:
Thanx in advanced!
https://www.sau.com.au/forums/topic/202040-new-tires/
On a Gts-t 265s are the widest you would get under your guards without scrubbing - but I am not sure you can get 16s that wide. Definitely go wider than 205s though - that is not enough rubber for standard power. 235s are probably the go sweet spot between price and grip.
https://www.sau.com.au/forums/topic/202040-new-tires/#findComment-3588967
Thanx buddy, appreciate the info. Short notice to the tyreshop unfortunately they only had 225's & i culdn be bothered ringing around. Im getting Nankang NS2's 225 55 R16 for $130each fitted...good price?
https://www.sau.com.au/forums/topic/202040-new-tires/#findComment-3589028
yeah sounds about right - may be a tad expensive, but I haven't bought 16s for many years. I take it you still have stockies? You should buy one of my sets of rim (insert shameless plug here)
http://www.nissansilvia.com/forums/index.p...p;#entry3871530
or these for $900
https://www.sau.com.au/forums/topic/202040-new-tires/#findComment-3589108
i wouldnt go bigger then the 205 on stockies if u go 235 it A) will look gay B) have a massive amount of sidewall flex just get some s/h tyres and save for some decent width rims 17 x 8.5 17x 9.5 in around the +20 offset
or C) less traction
https://www.sau.com.au/forums/topic/202040-new-tires/#findComment-3589396
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!)     I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding).   I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springs  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
    • Ok got some old tyres for you guys...my car has been sitting around un-driven for about 6 years now. I had it on the original rims with the shitty compliance tyres it got it with back in 2006, which were manufactured in 2004... Sidewalls eventually rotted and split open, obviously no air in them and the rims were holding the car up. Just swapped them with some 17" Work rims and tyres which are probably 10+ years old too but at least holding air
    • Nah mate, safe as $800k apartments
