Hi All.
Bran Nubian here. First Skyline ever in a few weeks. (Was getting a 03 WRX but changed my mind).
Excited about it.
DJ'ing career over, so now getting in car stuff.
Have been reading the forum over the last few weeks, thanks for all your posts, good back ground on everything from cruising to who and what I need to be aware of.
Any other issues I need to know about would be appreciated, on anything.
Who gives good prices on anything, particular products for cleaning your skyline, get serviced, where not to be after dark with your car haha...Appreciate the mind.
Starting from scratch (Turntablist pun).
Goldy.
https://www.sau.com.au/forums/topic/202045-go-for-what-you-know/
Welcome Goldy,
You will be able to find any info you need on Skylines and the "Skyline life" in these forums, they're a wealth of information.
Firstly - Trojan motorsports Mitchell, ESP racing Queanbeyan, Autotech performance Fyshwick - All are great shops for servicing and modification around Canberra.
There are plenty of shops that will help you out with vehicle servicing but the three I just named above would be my first choices.
If you need info on keeping your new baby clean there are plenty of us that know a secret or two about detailing :whistling: and if you do a search for "Detailing" on the local ACT forum you will find lots of tips to help you with the best products and hints to get the best result.
As for not leaving your new Skyline in places after dark - Dont ever leave it in ANY shopping centre car park for an extended period (if you go to the movies or something) because unfortunately theives target Skylines, try to avoid taking it anywhere near Queanbeyan too (their not so friendly over the border :huh: - joke).
Anywho, you should come out to the Museum one Friday night to meet us... We'll arrange to get as many people as we can out there soon.
Cheers :/
Mick
As for not leaving your new Skyline in places after dark - Dont ever leave it in ANY shopping centre car park for an extended period (if you go to the movies or something) because unfortunately theives target Skylines, try to avoid taking it anywhere near Queanbeyan too (their not so friendly over the border :D - joke).
While this is in general good advise, I see Skylines from 32's to 34's in car parks all day without being stolen. Get a good immobiliser and park sensibly. Saying that, unless you can afford ANY car be stolen, get insurance.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
