R33 Manual Conversion Parts
Yup. She's toast. You need refrigerant to carry the compressor oil to stop the thing from welding itself together.
After reading this and a few other comments, i'm starting to realize something... Since i got the car, the AC belt was never put on. I installed the belt on a few months ago because i was tired of melting in the hot car. Once i installed the belt, i was troubleshooting the AC and was turning the red switch on/off while driving the car to see if anything was happening. The engine was rebuilt by shop before i purchased the car and the shop might not have re-gassed the AC. Which means i was running the AC without any gas/refrigerant inside the compressor. The AC compressor now acts as if its seized up. I'm starting to think, i caused this damage.
Did you happen to read anything above anyone has said? Especially things like "it's going to need a complete retune"? IE, none of this will be safe to run once you plug it all in. And then secondly, the fact that pretty much none of your wiring will reach, and likely the throttle cable won't reach etc.
I was thinking the same thing when i saw the size of the smaller Toyota Compressor, but i'm not an AC expert. Where did you take it to get re-gassed?
Does anyone know if the cars came with a factory undercoating?
