  • Replies 88
Posted Images
  • 5 weeks later...
Gday all, Got the rocket back from painters and looks mint. Just chasing a bit of info regarding wheel sizes. The DR currently runs 17x9 sparcos, however i am trying to find some wheels a bit more suited to the age of the vehicle - watanabe copies or similar. What i need to know is do any of you r30 owners have dished wheels that still clear the guards, and if so could you please tell me the sizes and offsets? I dont want to buy the rims i think will clear, and not be able to use them.
Cheers.
Cheers.
Sport Max do these nice watanabe/panasport copies. Come in 16 inches, not sure on offsets or width.
Mate Ghostrider has a legit point, I had 355atw in my DR and it was an absolute monster to drive on boost, lotsa fun yes but not a lot of traction unless u eased it on, with 600+ forget it, too light and RWD only.
Well lucky its my car then and i can run whatever power i like hey. I am setting it up for a couple of glory runs down the strip then changing turbo and tuning for hillclimbing which is what it will be eventually used for. Rest assured i have had plenty of hi-po engines in my time and am under no illusions as to traction availability on the street. It seems to me that this forum is primarily for bagging other peoples rides and opinions instead of providing positive comments and feedback..........
If you believe that my engine produces too much power, thats great. I guess thats the reason that i bought this car and not you.
Check out the 17x9.5's in here. bout 1/2 way down.
http://www.skylinesaustralia.com/forums/Rb....html&st=40
Their called ROTA RB's.
Cheers mate, i checked them out once before but they dont do them in the offset i need. i am running drifteks at the moment and will probably stick with them for a while.
Thanks anyway
Yeah your car makes too much power :)
Give some to me!!!
I missed out on buying your car when it was here in Perth but baulked and brought in my own stocker.
Wish I'd bought it now as I'm up to the price he was asking spent on mine and it's not even licensed yet (maybe today ...fingers crossed)
Yep love your car
Never met a horsepower I didn't like
Yeah your car makes too much power :devil:
Give some to me!!!
Yep love your car
Cheers mate, someone talking some sense at last!!!! Yeah the cost of building from scratch sure adds up, but even though mine was semi-built when i bought it, i am still spending tons on it to get it to where it should be. I think that once you get to 20-30k, stop counting!! Look on the bright side though, you could be spending the same amount on a Hyundai..............
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
