Yer Pete's still got it last time i spoke with him...he's on this forum!
wal : Would love to keep seeing updates and progress tough car i bought my twin plate clutch from the two that owned that in QLD before selling it....
No worries. Speaking of clutches, im trying to source a twin plate as well, I reckon NPC in Brissy may be the go.
  • Replies 88
Posted Images
Ravenoak's DR & R34's would be a close tussle for the best I have seen. They are both excellent cars in their own right. As I said before, if I can make my PNV as good as them I'll be over the moon.
As for clutches ............ driveability can only be attained with a single plate clutch & today's technology might just give it to you. Have you researched maybe bigger diameter, heavier diaphram etc etc etc.
I will be looking at all these options when I need to replace the clutch in my DR. For my HR I have it all sorted I think, I'm looking at an Z32 TT 250mm single 6 puk clutch & modified VL Turbo assembly.
Cheers, D
NPC are an excellent clutch.
Excellent work with the car - I heard from a friend of Ross's it had gone up in flames, is good to hear its actually alive and well!
Have you ever driven a car with a twin plate clutch?
Yeah i had a 32gtr with nismo twin plate. Great bit of gear, not all twin plates are harsh.
Cheers, D
have to disagree with that statement...I've driven with a few twin plate clutches and they're oh so driveable so much so that unless you were told it was a twin plate you couldn't tell...
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
    • lol no cats running str pipes … might put the high flow back on but I suspect it might effect my ignition timing a bit.
    • That looks a bit like yellowing to me. If the rear bar was looking like that from rich idle, I'd ask the question, do you have a catalytic converter fitted, and fully working?
    • Oh yeah gets really bad down here. I’ll have to upgrade the heater and wind screen wipers as well for optimal performance.
